bent handlebar? - BMW Luxury Touring Community
post #1 of 7 Old Jan 8th, 2009, 3:31 pm Thread Starter
bent handlebar?
I noticed that the left grip on my 1999 KLT looks lower than the right grip when the wheel is pointed straight ahead. I measured it and from the floor to the grip it is 2.5 inches lower than the same measurement for the right grip to the floor. Could the bar be bent upward on the right?
I getting ready to replace the heated grips (foam grip is deteriorating and left grip doesn't heat) so I'll have the handle bar covers off. Anything I should look for in there?
The bike took a very low speed dive some months back on the right side on the road edge leading to my rocky driveway. (funny, my GS never took a dive off that three inch drop road edge between pavement and rock/gravel)
I had two other folks help me pick the KLT up. One of the guys jerked up hard on the right hand grip and bar while lifting it. Could that have bent it or twisted it in the handle bar mount? The bike was on a downward incline so it was a pretty good heft to get the bike back on its wheels.
It drives fine but the left grip feels a little low relative to the right grip.
Richard
1999 K1200LT
Utopia, Hill Country, Texas
Utopian is offline
post #2 of 7 Old Jan 8th, 2009, 8:40 pm
RocketRon's Avatar
Re: bent handlebar?
Try measuring with the bike on the center stand instead of the side stand.
Just kidding...I feel your pain!
I'd bet that what you described was the culprit. Those bars don't seem all that sturdy hanging out there as far as they do.
RocketRon is offline
post #3 of 7 Old Jan 8th, 2009, 9:27 pm
Re: bent handlebar?
Hi, Richard -
It definitely could be that the pressure put on the right handlebar during the lifting process, bent the bar, and/or twisted the bar at the clamp point under the fork bridge cover. Usually, if the clamping screws allowed the bar as much movement as you indicate, somethang shoulda happened to the handle bar trim/covers. They won't physically fit if the handlebar has been moved that far outta phase.
I'm guessing that you don't have a shop manual - so, I'll try to include an attachment that shows the procedure on how to adjust the handlebars (they're individually adjustable, btw). HTH
post #4 of 7 Old Jan 9th, 2009, 5:07 am
c00k1e's Avatar
Re: bent handlebar?
When removing the 2 screws from underneath each plastic cover - note which hole the long bolt came out of. Put them back in their wrong hole and you will be looking at an expensive plastic replacement. Don't ask me how I know :-(
c00k1e is offline
post #5 of 7 Old Jan 12th, 2009, 9:12 pm Thread Starter
Re: bent handlebar?
Thanks for the input. Though I'm not sure how a single bar could be "individually" adjusted - if you move the right side down doesn't the left side go down as well? the trim pieces fit fine. I'll double check the adjustment.
I was successful replacing the grips - though I had to fight with the little white lock block to get the grip connection wires out and the new grip wires back into the block again. What a pain.
Richard
1999 K1200LT
Utopian is offline
post #6 of 7 Old Jan 13th, 2009, 11:24 pm
leiboshi's Avatar
Re: bent handlebar?
Hi!
I purchased wrecked LT. It had been falling down to left side. Mainly plastic damages. And all plastics were removed when I got it.
When I was installing tupperware, I found out that handlebar was bent. Not much, but I could not install plastic cover to leftside well.
There is no way to adjust handlebar in bike itself. If you try to do any tricks, you will get problems with plastic parts in some another place. They won't fit anymore perfectly.
So Utopian, if your handlebar is bent so much, then best choise is to buy another one. There are always some used ones also in eBay. What I did? I took my handlebar off, pressed it a littlebit with hydraulic jack from that point where it was bent and it straightened into right position. It is made of steel tube, so it is possible to adjust, if right tools are available.
Regards
Leiboshi
leiboshi is offline
post #7 of 7 Old Jan 14th, 2009, 1:54 am
Re: bent handlebar?
I recently hit a very big pot hole and the result was both bars were bent doen towards the tank. Every time I turned the bars the indicators were switched on by the tank bag. I was miles from anywhere so I er stood on the pegs and pulled up on the bars and now they are back in the right position ! Actualy better position than before.
itsallpoo is offline
Bent Crash Guard Nebish K1200LT 10 Feb 1st, 2008 7:58 pm
Mounting Video Camera. Handlebar or Not? barryst1100 K1200LT 15 Dec 7th, 2007 4:27 pm
Handlebar pressure...i cfell Chit Chat 37 Nov 18th, 2006 10:18 am
Highway road hazzard, bent front rim Crestwood330 K1200LT 7 Mar 29th, 2006 8:39 pm
Highway road hazzard, bent front rim Crestwood330 K1200LT 0 Mar 27th, 2006 11:35 pm
