Problems after battery change - BMW Luxury Touring Community
post #1 of 5 Old Jan 8th, 2009, 11:12 am Thread Starter
hagar's Avatar
I replaced my battery, and everything seems fine, starts right up, etc. But about 5 minutes after I shut it down, all the blinkers come on and stay on, and will run the battery down. Does not matter if I leave the key in ignition, any position, or take it out. Any ideas?
Current rides:
2003 BMW 1200 LT (bought in 2006)
Past rides:
97 Kawasaki ZX11(bought new in 1997, sadly sold in September 2014)
89 Honda Hurricane (sold)
88 Honda Hurricane (traded on an SUV)
86 Kawasaki 1000R (stolen but recovered)
84 Honda 750F (traded on 1000R)
81 Suzuki GSX1100 (sold)
78 Suzuki GS750 (traded on GSX1100)
74 Yamaha RD50 (sold)
hagar is offline
post #2 of 5 Old Jan 8th, 2009, 11:27 am
deanwoolsey's Avatar
Re: Problems after battery change
I would disconnect the battery and put it on a regulated charger until it's fully charged, then reconnect it. I doubt that this will solve the problem but it's worth a try since it's easy and free. Your safety flashers are controlled by the computer. On my 2000 they can only be activated with the ignition on but will stay on once activated with or without the ignition on. They can also be cancelled with the ignition off. You might try cycling them on and off a few times and double check all your connections and harness for corrosion/damage/shorts.
deanwoolsey is offline
post #3 of 5 Old Jan 8th, 2009, 1:42 pm
They also will flash if the alarm is activated (it should also be making a lot of noise) but the alarm could be messed up as well. I would try arming and then disarming the alarm. Then see if it happens and if it does it again try to disarm the alarm to stop it. If that fails I would suspect the alarm is toast. there are some article posted in the files section that tell how to bypass the alarm. These articles are year specific as they have made three different alarm systems over the life of the production run.
post #4 of 5 Old Apr 13th, 2012, 10:44 am Thread Starter
hagar's Avatar
A long time since I last posted, cannot believe how time flies. Bike sat for a couple of years, between my wife being diagnosed with Hepatitus C and other life issues, the bike just sat till about a month ago. Towed it in to the Charlotte BMW dealer, and $2600 later it is back in action. Main problem was a bad alarm system, but they also found the fuel pump to be faulty, and the battery I installed 3 years ago did not pass the test. I also had a complete service done, draining, checking and refilling final drive, clutch, brake fluids, etc etc. Runs like a top now. Time to get back into biking!
Current rides:
Past rides:
hagar is offline
post #5 of 5 Old Apr 13th, 2012, 2:42 pm
Welcome back and enjoy the ride!!
battery problems colin K1200LT 2 Dec 18th, 2008 12:51 pm
Fob Battery Change? Buchnerb K1200LT 6 May 20th, 2008 8:07 pm
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 11:11 am
Dog-Gone battery charger question! Yuck! wardenross K1200LT 17 Oct 24th, 2006 2:31 pm
Bike only 14 months old - battery problems Thor1340 K1200LT 14 Aug 30th, 2006 5:59 pm
