Bleed which first - BMW Luxury Touring Community
post #1 of 2 Old Nov 8th, 2008, 12:19 pm Thread Starter
mpillis's Avatar
Bleed which first
Does it matter which you bleed first on an 05 LT with integral servo abs system, wheel ciruits or control unit?
Wish me luck!
Marc Pillis- MSF Rider Coach
Union, Kentucky
2005 LT
2004 R1150GS Adventure
2013 DR650
mpillis is offline
post #2 of 2 Old Nov 8th, 2008, 3:46 pm
Re: Bleed which first
It doesn't matter. Since they are not tied together. To do the front control and set the level properly you need to remove the handle bar covers and switch gear. Then loosen the clamp on the master cylinder to level it. Also cover ALL plastic near it and place a small piece of metal over the hole at the bottom of the resevoir as it will squirt straight up when you pull the lever.
Brake Bleed TrackAdaptor K1200LT 3 Jul 21st, 2008 6:50 pm
factory clutch bleed fitting part number? hmmmm90s K1200LT 7 Aug 15th, 2007 3:57 pm
Bleed Procedure for '05 K1200LT MSletten K1200LT 3 Jul 2nd, 2007 6:33 pm
Clutch Bleed tbarstow K1200LT 1 Feb 21st, 2007 11:26 pm
Bleed Cluch Renzo K1200LT 19 Nov 11th, 2005 1:13 pm
