Final Drive play - BMW Luxury Touring Community
post #1 of 5 Old Nov 6th, 2008, 9:08 pm Thread Starter
bikeit05's Avatar
Unhappy Final Drive play
Hello LT riders,
I own a 2000 KLT. the final drive has been tight up until now. The bike has 44000 miles on it checked the drive last week and it now has a small amount of play in it. Have others had play in the unit with out the rough bearing?
Dale Witzenburg
Oskaloosa Ia.
bikeit05 is offline
post #2 of 5 Old Nov 7th, 2008, 6:43 am
rattler50's Avatar
Re: Final Drive play
I honestly don't think you could have side play without a rough bearing. But, that's just me. I may not be as smart as my avatar looks..........
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #3 of 5 Old Nov 7th, 2008, 8:36 am
AlaskaFish's Avatar
Wink Re: Final Drive play
It may be something as simple as your Paralever (or Pinion) bearings have backed off a little on the torque. I had play in two directions, side to side and top to bottom with my rear wheel a few months ago, and thought I was looking at another dreaded FD failure! It turned out to be the Paralever bearings had to be re-torqued is all. If you watch very carefully and can see that the entire FD housing is actually moving with the wheel then the Paralever bearings should be the culprit. Easy fix!
HTH,
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #4 of 5 Old Nov 7th, 2008, 3:59 pm
RealWing's Avatar
I had play in my rear wheel as well and it was the paralever bearings.
2015 K1600GTL
1970 Plymouth Superbird 440-6bbl
1969 Plymouth Barracuda Fastback 340-auto
1969 Plymouth Barracuda Convertible, 6.1 L SRT8 Hemi transplant
RealWing is offline
post #5 of 5 Old Nov 7th, 2008, 5:32 pm Thread Starter
bikeit05's Avatar
Cool Re: Final Drive play
Thanks for the reply, I will check this out as soon as I get the time. This sounds alot better than rebuilding the final drive. Dale.
bikeit05 is offline
Play in final drive (2005 LT) Rethy K1200LT 13 Sep 30th, 2007 4:16 pm
final drive play, how much? pcra K1200LT 12 Aug 15th, 2007 3:43 pm
Final Drive Seal @ Drive Shaft Crestwood330 K1200LT 3 Jun 25th, 2007 7:58 pm
