Tire change - BMW Luxury Touring Community
post #1 of 13 Old Nov 6th, 2008, 7:51 pm Thread Starter
BigGeo's Avatar
Tire change
As a newbee I'd like to thank everyone for the great advise on this site. The 03 LT I bought in Oct. was my re-entry bike after 25 years. I've put 2000 miles on thus far and am hoping the winter holds off for a while. With the info I've garnered here I've changed the oil and filter and tomorrow I'm changing the tranny and FD fluid. While I was at the dealer buying the gear oil (he sold me 75/140 synthetic) and wining about finding a 14 mm allen for the tranny drain, a mechanic gave me an inch long 14 mm hex - great people at Warner BMW.
But taking the wheels off appears to be another issue. The dealer quoted $160 to mount and balance if I brought the bike in and they did all the work, or $80 if I brought in the wheels only. I've been looking on the web for Metzlers but they seem to have a different designation than I saw on the Hall of Wisdom but were classified as BMW OEM. The bike has now 19500 miles and the brakes still look good. Do you believe it is worthwhile to have the dealer do all the work for the additional $80?
BigGeo is offline
post #2 of 13 Old Nov 6th, 2008, 8:02 pm
Re: Tire change
I have yet to remove the front wheel on my 07 LT, but I did remove the back a couple of months ago as the original 880 wore out at 9K miles. Removing the rear wheel is a piece of cake. I'd definitely do that to save half of $80. Not having done the front wheel yet, I can't say for sure that it is worth $40, but I can't imagine it is that much more work than the rear. So, for me, I'd definitely take off your two wheels and install them again if you pay me the $80!
post #3 of 13 Old Nov 6th, 2008, 8:38 pm
Re: Tire change
Remove the front fender, then remove both calipers. The rest is pretty straight forward. There is a sequence for reassembly. Torque the axel nut ,then bounce the forks a few times THEN torque the pinch bolts. Followed by putting the other stuff back on. Don't forget to apply the front brakes a few times BEFORE moving the bike (don't ask). You decide if that is worth the $40.
post #4 of 13 Old Nov 6th, 2008, 8:42 pm
fpmlt's Avatar
Re: Tire change
I change my own tires, but would and did remove the wheels for changes prior to buying my own changer. And when you put the thing back together, PUMP THE FRONT BRAKE!!! Darn near cost me a new gate!!!
fpmlt is offline
post #5 of 13 Old Nov 6th, 2008, 8:58 pm
Re: Tire change
Yeah.. easy to do yourself.... just note direction of rotation...with a wax pencil to make sure tire gets mounted properly....
..remove the balance weights..
.. have them "balanced"...
.. it's pretty easy to remove as described above. I might add that you "tie" with a tiedown or other method, the "center stand" from somewhere on the bow back to the center stand. This will help keep bike from falling forward and then off the center stand.
.. also, "chock" the front of the bike near the under engine guard just enough to raise the front wheel about an inch off the floor.
... as you "remove" the front calipers, you need to "rock" them cw/ccw ... that will push the brake pads and caliper piston back into the caliper housing. Once you have them fully compressed you can "roll" the caliper out much easier. The rear comes straight out so not as important... but won't hurt to wiggle it a bit before removing.
...have some string to support the calipers.. don't let them dangle on the hoses.
... after replacing calipers, make sure you "pump" the brakes before you "turn on" the bike.
J.M.J...
Dcn Channing
post #6 of 13 Old Nov 6th, 2008, 9:26 pm Thread Starter
BigGeo's Avatar
Re: Tire change
Thanks for the help. The dealer has been very helpful thus far and I think I'll let him earn a couple extra $'s on this one.
BigGeo is offline
post #7 of 13 Old Nov 6th, 2008, 9:46 pm
BecketMa's Avatar
Re: Tire change
Right after I bought my LT I ran over an allen wrench on the interstate here in Tucson. Since it was a Monday, the local dealer was closed on Monday, I found a guy to come trailer my bike back to my house. He offered to bring it back to his yard and drop it off at the dealer first thing next morning.
I had them install a new rear Dunlop tire (OEm was DUnlop). I kept the receipt, I keep all of them.
With less than 4K on the speedo, I picked up a nail on the rear tire. I got on the internet and discovered I could replace the front and rear tire through a Kawi dealer, near me, for about the same price that I paid just to replace the rear tire thru the local BMW dealer.
I decode that it was time to see if another model tire, or brand name tire would have less propensity to pick up nails etc.
After making an appointment to have the new tires installed and waiting over 3 hours, I decide next time I'd rather yank the rims off and have tires installed.
Since that time, I yank my rims and have tires mounted and balanced.
BecketMa is offline
post #8 of 13 Old Nov 7th, 2008, 6:09 am
rab1967's Avatar
Re: Tire change
Since money was getting tight, the cost of a tire, mounting it, and balancing it, was going up I decided to do my own.
After reviewing information on the forums, cost had something to do with it too, I went with Avon Storms, Avon AV 55 120/70R17 front, and AV56 160/70R17 STORM ST REAR (correct tire for the LT ). You can get a set of front and rear tires from (http://www.motoxoutlet.com/ ) for about $250.00. There are plenty of other stores that sell these tires. They just happen to be the cheapest at the time.
I also use Dyna Beads to balance the tires. (http://www.innovativebalancing.com/ )
I have 10,000 miles on the front tire using Dyna Beads and the wear is even and the ride very smooth. I had to replace the rear tire at 7,000 mile due to a nail, but I had the same experience, even wear and a very smooth ride. Most of the miles are commuting to work.
I purchased a Harbor Freight tire changer with the motorcycle adapter and a No Mar Mount/Demount bar ( http://www.nomartirechanger.com/ ) I figured that once I changed three tires I would break even on the cost of the equipment I had to purchase.
Bob Brendel
05 LT, Light Metallic Yellow
99 LT, Totaled 3/09
97 HD Former Work Bike
88 GL1500
84 GL1200
S3 400 Kaw, too long ago to remember the year
175 Yamaha even longer
People sleep peaceably in their beds at night
Only because rough men stand ready to do violence on their behalf
George Orwell
rab1967 is offline
post #9 of 13 Old Nov 7th, 2008, 6:28 am
Bloodhound's Avatar
Re: Tire change
Changed both of mine before heading to the BMWOA Ralley in Gillette. I bought the rear Metzler from the web and the front tire from my local BMW dearler. They were $35 more than anywhere else(they gave me 15% discount as well)but I had to have one. Shop around, removing the wheels the first time may be little slow but once you do it, the next time will be easier. Good luck
2002 LT 'The Golden Girl'
Bloodhound is offline
post #10 of 13 Old Nov 7th, 2008, 9:45 am
Re: Tire change
I go thru tires, so I bought the nomar and do my own.
Just ordered from swmoto, 354 delivered to my door. Last year I think I got the same tires for about 260 delivered, when gas when thru the roof.
I save about 200 bucks, its over 550 at the dealer now to do this job.
I do my oil changes too, save about 65 bucks each change (synthetic, etc). Oil has shot up too, its around 12 bucks a qt now for BMW synth...ouch!
ldbikin is offline
post #11 of 13 Old Nov 7th, 2008, 9:53 am
Re: Tire change
A tire change on the LT is cake. The wheels come off real easily, and you don't have to take it to a motorcycle shop to change the rubber, you can take it to a tire shop, which will charge a lot less. I paid only $20, but I had to take the rotor off the front wheel, no big deal.
Caveno is offline
post #12 of 13 Old Nov 15th, 2008, 3:48 pm Thread Starter
BigGeo's Avatar
Smile Re: Tire change
Thanks all for the encouragement. I decided to attempt the wheel removal and it was quite straight forward. Purchased the Metzlers from Ronayers.com and recieved them in 10 days. Had them mounted and balanced at a tire store and saved beaucoup $'s. Quickly running out of riding weather up here.
Thanks again.
BigGeo is offline
post #13 of 13 Old Nov 16th, 2008, 8:32 pm
bblalock's Avatar
Re: Tire change
Do yourself a favor and invest in the Clymer manual for the LT. Worth every penny. I take my wheels off and take them to the local Honda MC dealer. They mount the tires I get from them. I pay about what the internet has them for.
Benton Blalock
"I ride.....the bike doesn't"
'18 Honda Africa Twin Adventure SportDCT
'12 Kawi KLR 650 "Dirty" - traded in
'08 LT Black "Fireball" 113,000+ miles(RIP- transmission - may be seen on the road again)
'05 LT Yeller er Gold? "Ophelia"(RIP- fire) 80,000 miles
'04 R12CLC (RIP- hurricane) 36,000 miles
230,000+ BMW miles
'Rounder'
bblalock is offline
Tire Angel in Jasper BC Bob_Diachuk K1200LT 8 Jul 6th, 2008 7:48 am
First DIY tire change, irons only, not so bad... JGroves K1200LT 5 Jul 19th, 2007 10:16 am
Tire changing my way CharlieVT Bike Talk 7 Apr 11th, 2007 11:25 am
Bridgestone BT020R 160/70R-17 tire failure. mudman Tires 23 Aug 28th, 2006 2:36 am
