Starting Smoke - BMW Luxury Touring Community
post #1 of 10 Old Nov 5th, 2008, 7:56 pm Thread Starter
Starting Smoke
Looking at a 2001 K1200LT with 56K miles. Is there significance if there is white smoke on startup after sitting a couple weeks on it's side stand. Smoke goes away after a few minutes of running. It has no problem in starting.
Casper1951 is offline
post #2 of 10 Old Nov 5th, 2008, 7:59 pm Thread Starter
Re: Starting Smoke
Never mind. I should have performed a search first. Seems this is common for K-bikes set on their side stands immediately after shutting down.
post #3 of 10 Old Nov 5th, 2008, 8:00 pm
knoticalone's Avatar
Re: Starting Smoke
The K12LT's do that if left on the side stand. When on the side stand oil runs toward the cylinders and seeps around causing the smoke. If left on the center stand or not put on the side stand until about 30 seconds after shutting it down, it virtually eliminated this.
Just another "feature" of the k12
knoticalone is offline
post #4 of 10 Old Nov 6th, 2008, 7:58 am
razman10's Avatar
Re: Starting Smoke
Smoke??? After sitting on the sidestand? On an LT??? I've never heard of such a thing!!!
Yep... Nothing like a big fat pig that smokes!
__________________
Ray "Razman"
2004 BMW K1200LTE - Rosie (As in Whole Lotta Rosie)
1996 HD Sportster XLH883 Hugger (sold)
1986 Honda Interceptor VF500F (sold)
Your chosen perspective changes everything. - Unknown Author
"You are what you repeatedly do. Excellence is not an event - it is a habit." - Aristotle; 384-322 BC, Greek Philosopher and Scientist
razman10 is offline
post #5 of 10 Old Nov 7th, 2008, 12:46 am
leiboshi's Avatar
Re: Starting Smoke
Oh no. You have serious problem. To avoid it, drain all engine oil out from your motor. Then it won't smoke anymore
To be more serious:
Smoke is not an option. You get it free of charge when you purchase LT. It is shame that BMW copied that feature from Goldwing. They shouldn't.
You can avoid it (or at least there will be much less smoke when starting) by using center stand instead of sidestand.
Regards
Leiboshi
leiboshi is offline
post #6 of 10 Old Nov 7th, 2008, 5:00 am
c00k1e's Avatar
Re: Starting Smoke
It is an undocumented 'feature', pre-oiling pistons.
c00k1e is offline
post #7 of 10 Old Nov 8th, 2008, 3:37 pm
sparky_k1200lt's Avatar
Re: Starting Smoke
And just like my Wing, the smoke only comes out of the left side pipe
...Bob
1978 GL1000
sparky_k1200lt is offline
post #8 of 10 Old Nov 8th, 2008, 4:35 pm
blueknightga6's Avatar
Re: Starting Smoke
UMMMM Don't we have a pipe only on the left side?
Chris Ehlbeck
blueknightga6 is offline
post #9 of 10 Old Nov 8th, 2008, 5:29 pm
Re: Starting Smoke
But unlike Honda, BMW correctly pre-oils ALL cylinders, not just half of them!
post #10 of 10 Old Nov 8th, 2008, 6:00 pm
yechave's Avatar
Re: Starting Smoke
I am unable to use the center stand. I prop up the side stand just enough, and have not had a smoke issue since the first week we got our LT...at which point it smoked so bad the first few times I started it, I thought the motor was shot. Didn't smoke when we first looked at it, or during the test ride.
Imagine the shock to find myself in a cloud of billowing smoke from a newly purchased, pre-owned BMW!
I have noticed some oil consumption when I am running in the 7K rpm range however!
yechave is offline
Heavy light colored Smoke after starting mhoop K1200LT 12 Oct 11th, 2008 8:54 am
'96 r1100rt smoke at stop signs and start up chaz RT Series 2 Oct 23rd, 2007 8:23 pm
Smoke at start up what is the Cat doing? coug66 K1200LT 7 Oct 9th, 2007 9:47 am
Question on Start-up Smoke Andy-SC K1200LT 7 Jan 17th, 2007 3:20 pm
Smoke at Start up cavsfan2703 K1200LT 5 Aug 8th, 2006 4:52 pm
