Broken cruise control cable - BMW Luxury Touring Community
post #1 of 7 Old Nov 4th, 2008, 1:22 pm Thread Starter
My cruise control stopped working a couple K miles ago. Searching this terrific forum convinced me it was probably time to change the throttle cables. Well once I got her all stripped down it was very clear that the cruise control cable had snapped. So I have a cable ordered, but I'm wondering how it is disconnected from the cruise control unit. My Clymer manual merely says to disconnect it, not much help. I've search this forum and found lots of stuff on cruise control problems but not on the cables.
The cable goes into a plastic cover or boot that looks like it might have to be rotated to be released, but I'm not sure. Any help or insight would be appreciated.
Dave Granzin
'00 K1200LT (107 K Miles)
dgg155 is offline
post #2 of 7 Old Nov 4th, 2008, 2:34 pm
tbarstow's Avatar
Re: Broken cruise control cable
Make sure you upgrade your throttle cables as well.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #3 of 7 Old Nov 4th, 2008, 9:31 pm
The cruise control unit is easily visible once you remove the left tupperware. You should see the cable clearly run into the unit. Check out the attached docs for the throttle cable.
Caveno is offline
post #4 of 7 Old Nov 5th, 2008, 8:13 pm
GBarnes's Avatar
Dave Granzin
Yes, that's exactly what you do. Turn the plastic piece about 1/4 turn and pull it out. The cable attaches to a cloth ribbon. Once you have it off, it's easy to figure out.
GB
George Barnes
'06 K1200LT
'01 K1200LT, totaled with 180,000 miles, 10/18/07,
'97, '99, '01, '05, '07 & '09 Iron Butt Rallies, (won the '99)
IBA#146
GBarnes is offline
post #5 of 7 Old Nov 6th, 2008, 9:52 am Thread Starter
Thanks for your help. The Cruise cable hasn't arrived yet but I am working on installing the throttle cables. Sure it tight work.
dgg155 is offline
post #6 of 7 Old Nov 6th, 2008, 10:14 am
GBarnes's Avatar
Yes, it is. Patience, grasshopper
George Barnes
'06 K1200LT
IBA#146
GBarnes is offline
post #7 of 7 Old Nov 6th, 2008, 10:44 am Thread Starter
I was so impressed with your "States visited signature" that I figured out to add my own. Interesting, I did not realize I had a hole right in the middle.
Dave Granzin
'00 K1200LT
"04 R1159GS
'93 Honda Nighthawk 750
Dave Granzin
Penn Yan, NY
'03 K1200LT
'05 R1200RT
'00 K1200LT (Killed by Bambi attack)
'04 R1150GS (traded for RT)
'87 K100RS (sold)
dgg155 is offline
MCCruise.com electronic cruise control installed Randy GS Series 16 Jun 22nd, 2007 9:04 am
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Strange Cruise Cable Question Dochatley K1200LT 4 Mar 1st, 2006 9:38 am
Cruise Control Cable Dochatley K1200LT 2 Feb 14th, 2006 4:14 pm
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
