Sliding Clutch - BMW Luxury Touring Community
post #1 of 4 Old Nov 4th, 2008, 5:33 am Thread Starter
K1200LT-TH's Avatar
Sliding Clutch
Hi guys
Been reading your advices and comments about how to fix Sliding clutch.
just a quick question, IF clucth plates are contaminated\soaked with oil(Brake oil, not engine oil) is it enough to change plates and gaskets as nothing else is damaged?
I have 2004 LT with 14000Miles on the clock
K1200LT-TH is offline
post #2 of 4 Old Nov 4th, 2008, 5:52 am
rattler50's Avatar
Re: Sliding Clutch
If you replace your clutch it's a big job and your bike will be torn down to just about the frame and front wheel. It's a good idea to replace all the seals inside your bell housing (trans seals and rear main seal) while you have it open. You also need to drill the bleed hole in the bottom of the housing that holds the slave cylinder so the brake fluid will drain out before contaminating your new clutch. And of course you will replace the slave cylinder if that is what caused your clutch failure. By the time you get all this done, you will be very familiar with your LT. Good luck............
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #3 of 4 Old Nov 4th, 2008, 6:32 am Thread Starter
K1200LT-TH's Avatar
Re: Sliding Clutch
Hi Rattler
Thnx for info and yes all the seals ofcourse need's to be changed and "slave" if it's the cause of the damaged, but generally nothing else.
Weep hole is already to do list.
post #4 of 4 Old Nov 4th, 2008, 9:02 am
leiboshi's Avatar
Re: Sliding Clutch
Originally Posted by rattler50
If you replace your clutch it's a big job and your bike will be torn down to just about the frame and front wheel...
Not true. Just take rear wheel, final gear, axle with housing, center stand and tranny away. Also part of tupperware has to be removed. This is how I did it.
Regards
Leiboshi
leiboshi is offline
Take off, 'eh? Starting the LT from stop... petevandyke K1200LT 26 May 30th, 2012 9:48 am
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 10:19 am
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 9:00 pm
