"no radio" message - BMW Luxury Touring Community
post #1 of 9 Old Nov 3rd, 2008, 4:40 pm Thread Starter
"no radio" message
I had a question - my radio is not working and I am getting a message of "no radio" now wait a min I can see the darn thing it is there! LOL any suggestions?
magiccarpetrider is offline
post #2 of 9 Old Nov 3rd, 2008, 4:48 pm
sheldan2's Avatar
Smile Re: "no radio" message
do a hard reset by disconnecting the battery for a while, it should fix the problem
sheldan2 is offline
post #3 of 9 Old Nov 3rd, 2008, 5:00 pm Thread Starter
Thanks I did a search before I posted and didnt find anything till the simular threds came up below, Was not aware of the Throtle sensing set with the key and the throtle twist till now also. So I have some things to try. thanks for the help and the patietnts Will let you know if I get it!
post #4 of 9 Old Nov 3rd, 2008, 7:04 pm Thread Starter
Well the "reset" didnt work so I will try to replace the fuse behind the radio this weekend - its a 15Amp? then I have to remove the side panels and tank cover to get to it right? thanks in advance!
post #5 of 9 Old Nov 3rd, 2008, 9:05 pm
Make sure you put the right fuse in there... because once you let the "smoke" out it will probably never be the same.
J.M.J...
Dcn Channing
post #6 of 9 Old Nov 3rd, 2008, 9:27 pm
Florian's Avatar
had the same issue, Im sure youll find like I did that the fuse is fine. You need a new radio. DAMHIK
F
BMWMOA
12 GTL
Florian is offline
post #7 of 9 Old Nov 4th, 2008, 2:24 am
WAL
WAL's Avatar
I have the same problem with mine. I don't believe it is the fuse mine will work for awhile then get the no radio message this will happen for a few days then it will start working again for maybe weeks then go out again. I have not found any loose connections but it did get much better when I installed a new battery. I know that it does not seem feasible but it seems if the battery is at all in a weakened state the radio starts to act weird. Just a thought if nothing else I feel your frustration.
WAL is offline
post #8 of 9 Old Nov 4th, 2008, 9:39 am
I've had that happen several times on my '02. I've always traced it to water getting into the radio control element, the thing with the buttons and display. It dried out on it own a couple of times, but finally quit. Dissassembly and cleaning of the circuit board with a Q-tip, electrical contact cleaner, and dielectric grease helped for a while.
Ultimately, the fader failed, and I replaced the control element with a used one--and make sure to cover it when it looks like rain.
IIRC the fuse in back of the radio is 10 amp.
Motor On ,/'
jkersh1 is offline
post #9 of 9 Old Nov 4th, 2008, 10:23 am
Had the same issue with mine and it was the fuse in the radio - not a fun job to replace.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
"NO RADIO" pete1102 K1200LT 2 Apr 29th, 2008 3:03 pm
"No Radio" bulletbill K1200LT 6 Nov 20th, 2007 7:45 am
"NO DISCS" message rguppy K1200LT 7 Apr 16th, 2007 12:49 pm
"No Radio" alstrickland55 Intercom, CB, & 2-Way Radios 1 Apr 8th, 2007 11:39 am
"NO RADIO" on LT simon K1200LT 6 Aug 23rd, 2006 2:14 pm
