Fuel supply & return hoses? - BMW Luxury Touring Community
post #1 of 11 Old Nov 1st, 2008, 11:06 pm Thread Starter
Has anyone replaced the fuel supply and return hoses between the fuel pump outlet tubes from the tank and the quick connects?
I had one leak from the end of the hose at the clamp and fixed it by adding a second clamp there.
Since the hoses are 10 years old I would like to replace both if I could find a part number. Can someone point me in the right direction?
Thanks!
Joe
EncoreJoe
"Ride, boldly ride, ... If you seek for Eldorado!"
'10 Triumph Tiger 1050
EncoreJoe is offline
post #2 of 11 Old Nov 1st, 2008, 11:15 pm
Axle's Avatar
Re: Fuel supply & return hoses?
try this
http://www.realoem.com/bmw/showparts...82&hg=16&fg=05
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 11 Old Nov 2nd, 2008, 12:10 am
If it is the hoses outside of the tank just get "fuel injection" fuel hoses from any auto parts store. If you intend to replace the hoses INSIDE the tank, then you are going to be better off getting them from BMW.
The difference is the outer jacket on the hoses. The ones for inside are SAE30R10 spec and cost around $30/foot. The other hoses are SAE30R9 and are cheap. If you use SAE30R9 hose inside the tank the outer jacket will swell and the hose will fail.
BTW, the hoses are all 5/16" inside diameter.
Morley is offline
post #4 of 11 Old Nov 2nd, 2008, 1:19 pm Thread Starter
Thanks for the information.
These are the outside hoses. I'm not able to find anything with a bend similar to the stock hoses so may have to go to the dealer.
I don't see them listed on the oem parts drawings on-line.
Joe
EncoreJoe
post #5 of 11 Old Nov 2nd, 2008, 1:22 pm
Joe
I replaced mine with plain injection hose and made them a little longer to compensate for the bend I needed.
Morley is offline
post #6 of 11 Old Nov 2nd, 2008, 1:31 pm Thread Starter
Good idea. I think I'll try that so I can get everything put back together..
Thank you.
Joe
EncoreJoe
post #7 of 11 Old Nov 2nd, 2008, 2:48 pm
wacolt's Avatar
Good luck getting the hoses from BMW. I waited a month to get three of them; after 6-weeks of waiting for the 4th 90-degree hose, I gave up.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
post #8 of 11 Old Nov 2nd, 2008, 6:04 pm
Yeah.. use Fuel Injector hose.. if you need to make bends.. you could use some brass barbed 90's...with screw stainless steel clamps to keep tight hose turns from "crimping"
J.M.J...
Dcn Channing
post #9 of 11 Old Nov 2nd, 2008, 8:56 pm
grifscoots's Avatar
I bought some fuel injection hoses for a car, with the bend already in them and then cut them to size.
-=grif=-
Grok
grifscoots is offline
post #10 of 11 Old Nov 3rd, 2008, 11:17 am
Here are the part # and prices for the four pieces that I ordered from the dealer. they took 6 weeks to get.
1 #13317687266 return fuel hose $41.23
1 #13317687267 " " " $77.12
1 #13317687268 inlet fuel hose $83.25
1 #13317687263 " " " $15.20
danbrown is offline
post #11 of 11 Old Nov 3rd, 2008, 11:18 am
Yup, that's a great idea, too, Grif! When Misty needs new tubing I'm going to do that... where possible.
J.M.J...
Dcn Channing
fuel return through oil cooler? kayakkermit Other K-Bikes Discussion 4 Sep 20th, 2008 7:09 am
Fuel Return Line BobbyLT K1200LT 1 Feb 6th, 2008 9:34 pm
Return Fuel Line/Aux Fuel cell Problem lvahl K1200LT 5 Apr 14th, 2007 6:00 am
