Need replacement parts list - BMW Luxury Touring Community
post #1 of 5 Old Nov 1st, 2008, 11:15 am Thread Starter
I am wondering if anyone might have a list of replacement parts ie., seals , O-rings, etc. that were purchased when removing and installing the transmission in a K1200LT. (2000 yr.)
I plan on replacing the slave cylinder (68k miles), drilling the weep hole, and shocks.
I have searched and read a lot of searches on this site and have the Clymer manual but all suggestion will be carefully considered.
I have several egg cartons, marking paint pens, sandwich bags, digital camera, etc. in preparation.
I very much appreciate all the help you all provide to this site. My closest dealers are around 175-200 miles away so you all have been a real help.
little_jake
little_jake is offline
post #2 of 5 Old Nov 1st, 2008, 2:53 pm
Re: Need replacement parts list
No need to pull the tranny when replacing the slave cylinder and drilling the weep hole. You just have to remove the swing arm to get clearance.
post #3 of 5 Old Nov 1st, 2008, 2:58 pm
Here is a thread with a lot of information on parts people have used. You do NOT need all the parts listed though.
http://www.bmwlt.com/forums/showthre...tch+parts+list
You WILL need the clutch plate, all the seals listed for transmission and engine main oil seal/O-ring (definitely replace those), the six new clutch attach bolts, a new engine output shaft nut and thrust washer, and crush washers for the slave cylinder.
Listed is the clutch actuation shaft and felt ring. If your bike already has the shaft that is grooved for the felt ring, you will not need a new one.
Unless your clutch cover plate and pressure plate are grooved or heat checked, you do not need to replace them. Just clean everything well with solvent.
Tip: You do not need a special tool to set the engine output shaft nut angle properly. It is torqued, then turned 60 degrees further, which just happens to be one nut flat. Just mark the position of one flat after torquing , turn to the next one.
Do you have the cutaway 30MM socket and allen wrench for the swing arm nuts? That and a holding bar for the clutch drive plate, and two cutoff 8MM bolts for aligning the transmission for re-install are the only special tools needed.
post #4 of 5 Old Nov 2nd, 2008, 6:51 pm Thread Starter
Thanks Ken,
The problem is that when my Center stand took on the rail of a country RR crossing at the same time my front wheel dropped in to a pot hole, in the dark going to work, three of the brackets on the transmission that hold the center/side stand went south. The forth is still holding but has a bad crack.
I am working with J. Fisher (AlaskaFish) for the one out of the bike he is parting out.
Glenn
post #5 of 5 Old Nov 2nd, 2008, 7:01 pm Thread Starter
David,
Thank you for taking the time to respond to my post, it is going to be very helpful.
I had printed out the parts list but wasn't sure all were needed so your comments were most welcome. I have a good friend that has a welding shop so I think he can cut me a 30MM socket, I may have him weld the brackets back on the old transmission, keep it for a spare.
As far as the drive shaft, u-joints, boots, etc., I will decide as I go...
Thanks again,
Glenn
Shopping List for Clutch Replacement indranus K1200LT 7 May 10th, 2008 9:04 pm
Clutch Replacement Parts? bulletbill K1200LT 2 Dec 28th, 2006 8:34 pm
Arai replacement parts source? tkramer Rider's Gear & Luggage 2 Jul 26th, 2006 3:21 pm
Where is an Online Parts List? JB3 K1200LT 11 Apr 27th, 2006 7:53 am
2000LT Clutch Replacement Parts List mtrevelino K1200LT 2 Jan 13th, 2006 7:38 pm
