Adding break fluid to an 02 under the rear seat - BMW Luxury Touring Community
post #1 of 7 Old Oct 30th, 2008, 7:40 pm Thread Starter
I think I need to add a little break fluid and it seems that the only opening, (there are 2) is a 6 sided hex type plastic bolt with a tube running out of the top. One is easy to get to, the other is under the plastic. Do both need to be filled? Does the side cover need to be removed to fill the one that seems to be very hard to get to? Any tricks or hints? Looks like a job for the turkey baster.....
found answer here, but it did not come up in my search!
http://www.bmwlt.com/forums/showthread.php?t=7641
post #2 of 7 Old Oct 30th, 2008, 9:58 pm
Axle's Avatar
Re: Adding break fluid to an 02 under the rear seat
Dan they both need to up to the max line or you will get the wig wag on the dash I found that removing the pillion seat made it easier to get to the resivoir used pointy nose pliers to undo the nuts they are not tight just awkward never took off the side panels and yep used a small plastic kitchen funnel to direct fluid into the res.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 7 Old Oct 31st, 2008, 5:38 am Thread Starter
Yep..... thanks. Noticed it's been about two years since the last flush and the fluid is between tea color and red...... It's that time again... always something!
post #4 of 7 Old Oct 31st, 2008, 9:21 am
SilverBuffalo's Avatar
Dan
you should be able to "get to" both of the reservoirs without removing any tupperware,
turkey baster or eyedropper is the key, they're only going to take an ounce max.
keep in mind that the reason your fluid level went down
is because your brake pads have gotten thinner.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #5 of 7 Old Oct 31st, 2008, 9:29 am
On a related matter, I'm having trouble opening the document at the link below. I keep getting the encoding pop-up whenever I try to open it. Can someone attach another copy?
http://www.bmwlt.net/ubbthreads/show...&Number=162457
Frank Carroll
jarhead354 is offline
post #6 of 7 Old Oct 31st, 2008, 2:20 pm Thread Starter
I tried and I can't get it to open either...
post #7 of 7 Old Oct 31st, 2008, 2:22 pm Thread Starter
Originally Posted by SilverBuffalo
Dan
Thanks, I'll give the break pads a check too. I found that my battery needed a little boost too and the cold weather also caused the fluid to drop just enough to set off the red alert. Warm weather today; full charge batter, no brake alarm. I'll add a few drops later this weekend cause colder weather is coming...
Raising the seat for tall guys pozo_izquierdo K1200LT 12 Jul 1st, 2013 7:27 pm
Adding heat to the seat? Rick-L K1200LT 20 Nov 27th, 2009 11:27 am
Accessing rear brake fluid reservoir hardrock121 K1200LT 8 Nov 1st, 2008 12:44 am
Adding led liscense plate to rear brake harness Torch K1200LT 5 Aug 22nd, 2007 1:13 pm
Rear seat tie down systems pozo_izquierdo Rider's Gear & Luggage 7 Jul 10th, 2007 5:19 pm
