Valve CHECK lobe position? - BMW Luxury Touring Community
post #1 of 8 Old Oct 29th, 2008, 2:27 pm Thread Starter
mpillis's Avatar
Ok I am starting to get confused. I have the Gunsmoke and Sayegh video and done research. I am confused on the position of the lobes when checking the clearance. On Gunsmoke it says that the lobe should be pointing straight out and draw an imaginary line from tip of lobe thru cam to center of bucket. But when the lobe is straight out there is not a straight line to center of bucket. I have to go a little further to get a straight line from lobe tip to bucket center. But when I watch video it looks like the lobe IS straight out at same line as the place where a place that a screw would go into. Should I line the lobe up with the screw hole or what? Help please!!!
Marc Pillis- MSF Rider Coach
Union, Kentucky
2005 LT
2004 R1150GS Adventure
2013 DR650
mpillis is offline
post #2 of 8 Old Oct 29th, 2008, 2:45 pm
amarider's Avatar
Re: Valve CHECK lobe position?
Your Cam Lobe has an area of which 50% is round, so the lobe point can be off center by about 20% without a problem. As long as the round part is in the back your good.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #3 of 8 Old Oct 29th, 2008, 3:02 pm
sully2028's Avatar
I line up the lobe with the center of the buckets, which makes it off center from horizontal. For the intake valves, the lobe was just above horizontal and for the exhaust valves, just below horizontal. You can see in the attached thumbnails, valve 4 intake and valve 2 exhaust are both ready to measure. Then you rotate the rear wheel (bike in 5th gear) to align the next set of valves.
Name:	valve cover removed.JPG
ID:	20365   Click image for larger version
Name:	valve 4 intake ready to measure.JPG
ID:	20366   Click image for larger version
Name:	valve 4 intake being measured 0.015 mm.JPG
ID:	20367   Click image for larger version
Name:	valve 2 exhaust closeup.JPG
ID:	20368   Click image for larger version
Name:	valve 2 exhaust ready to measure.JPG
Name:	valve 2 exhaust being measured 0.025mm.JPG
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
sully2028 is offline
post #4 of 8 Old Oct 29th, 2008, 3:07 pm
sully2028's Avatar
Here is the explanation for the thumbnails in my previous post:
Thumbnail 1 - valve cover removed
2 - valve 4 intake ready to measure
3 - valve 4 intake being measured 0.015 mm
4 - valve 2 exhaust closeup
5 - valve 2 exhaust ready to measure
6 - valve 2 exhaust being measured 0.025mm
Dan Sullivan
2011 vStrom DL650
1999 K1200LTC
Hillsborough, NJ
post #5 of 8 Old Oct 29th, 2008, 3:46 pm
joegottberg's Avatar
FWIW I'm not sure who first created it, but this sheet was handy for me to record the clearances:
Valve Clearance Check Sheet
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #6 of 8 Old Oct 29th, 2008, 3:56 pm Thread Starter
mpillis's Avatar
Thanks to everyone. I think I did it right by be a little off of straight out. Now I have to figure out if I actually have the drill bit seated in the chain tensioner. It goes in an inch but it is loose in there and does not seem like it is engaging anything. I can just push and pull it in and out easily. Does that mean I am not "in the groove"?
Union, Kentucky
2005 LT
2013 DR650
mpillis is offline
post #7 of 8 Old Oct 29th, 2008, 8:36 pm
It is not in place.
It will go in over 1-1/2". At first it will be loose, but let it sit for a couple of minutes so that the spring in the cylinder pushes the tensioner back out until the pin stops it. Then it will be fairly tight.
Here is a picture of the tensioner tool I made. You can see that it is 1-5/8" of straight pin below the "handle". It was pushed in until the handle bottomed out on the timing cover.
You can have the cam lobes pointed considerably (+/- 30 degrees)to either side of perpendicular to the follower face and still be fine.
post #8 of 8 Old Oct 30th, 2008, 4:11 am Thread Starter
mpillis's Avatar
Thanks I didn't think it was in enough. I will work on it some more this evening.
Union, Kentucky
2005 LT
2013 DR650
mpillis is offline
valve check, where did I go wrong??? rkdrmr1 K1200LT 24 May 31st, 2009 8:41 am
Fuel evaporation check valve yechave K1200LT 6 Apr 25th, 2008 4:21 pm
Valve cover gasket sealant REWDOC K1200LT 20 Jul 22nd, 2006 8:06 pm
Outcome of Valve check? artk50 North West 18 Apr 26th, 2006 10:44 am
Need Help Finding Kawasaki 1000 Specs S2DOG Chit Chat 4 Jan 18th, 2006 6:45 am
