Shock life.... - BMW Luxury Touring Community
post #1 of 9 Old Oct 26th, 2008, 6:50 am Thread Starter
ltlfeat's Avatar
Shock life....
How long before the OEM shocks will need to be replaced ?
I have 35k on mine,anyone here gone beyond 50k....60k...more ?
ltlfeat is offline
post #2 of 9 Old Oct 26th, 2008, 7:15 am
c00k1e's Avatar
Re: Shock life....
Some will say 12k. Personally I have 50+ and a top up or two.
Ohlins are said by some to be the best, but they sure cost.
c00k1e is offline
post #3 of 9 Old Oct 26th, 2008, 12:11 pm
Senior Member (ret.)
RaffyK's Avatar
Re: Shock life....
LT shocks are 'dead' by the time they have 25K miles on them. It also depends on your riding style and the shock setting.
Raffy
RaffyK is offline
post #4 of 9 Old Oct 26th, 2008, 1:53 pm
BobShirley's Avatar
Re: Shock life....
I have 85,000 miles on my 2000 LT. I keep asking my mechanic, Dave Clark of Forever Endevor Cycles, if they should be replaced. After a test ride, he says they are fine and don't bother. I am a pretty conservative rider and all of the miles are two up.
Bob Schrader
Wentzville, Mo.
'00LTC
BobShirley is offline
post #5 of 9 Old Oct 26th, 2008, 5:37 pm
yechave's Avatar
Re: Shock life....
We had more than a couple people from the dealership test ride our new to us 99LT, and told us there was nothing wrong with the OEM shocks at 41k.
After reading the many posts on the forum, I took it to another dealer and watched the 140lb tech bottom out as he road down the road. Our two up weight with basic stuff in the bags is around 400lbs, so you can imagine how that was working out.
One of the owners prior to us, used the bike to haul a trailer.
I purchased the Ohlins online from Kyle racing (must less than the dealer we purchased the bike from wanted), I took the time to install them, and they absolutely were very much in need of replacement.
yechave is offline
post #6 of 9 Old Nov 2nd, 2008, 8:12 am
txpiperman's Avatar
Smile Re: Shock life....
Just finished the topping up of my preload adjuster last night and the results were incredible. Before you purchase new shocks for your LT I strongly suggest getting your local shop or a friend to do this procedure if you can't do it yourself. If you do it yourself remember to note the orientation of the hose from the banjo fitting before you remove it, use a crescent wrench to hold the adjuster when removing the bolt on the banjo fitting and place a rag under the whole operation to keep your bike clean and catch the brass washer if you drop it. Having a friend there to hold the hose up really helps. I had to do mine twice. Upon testing it I had 13.5 revolutions until I felt resistance before adding oil. After the first attempt it went to 2.5 and after the second it went to 0.5. A bottle of hydraulic oil cost me $4.95 at the local auto parts and I used about $0.15 worth for the repair. Total time: about 20 min. to do it twice. The oil was BAR'S Leaks Jack Oil. It also has a seal conditioner in it with a handy pour tip on the top of the bottle. These are the instructions I used thanks to BMWMick: http://www.bmwlt.com/forums/showpost...09&postcount=5. Before this I was dodging bumps in the road and had a lot of clanking sounds coming from the bike in bumpy areas. Also had tire rub on the rear from bottoming out riding two up. After, it felt like a whole new bike, which is an 02 with 36k on it. Hope this helps someone as much as it has helped me. Thank you BMWLT for your site!
txpiperman is offline
post #7 of 9 Old Nov 4th, 2008, 3:57 pm
Talking Re: Shock life....
I only have 125,000 on my original shocks, they are a little tired, would love to have a set of 30,000 mile ones.......
Kieth is offline
post #8 of 9 Old Nov 4th, 2008, 4:40 pm
retiredjj's Avatar
Re: Shock life....
On the stock shocks we can only fiddle with the rear pre-load and maintain the adjuster. Unfortunately the front shock isn't adjustable and can wear out before the rear. Perhaps when the bike starts feeling like the shocks are going away, replacing just the front might take care of the issue.
2002 R1150GS Adventure (current)
2000 K1200RS
1999 K1200LT (current)
1998 R1100RT
1985 Suzuki GS1150E
1985 Kawasaki Ninja 900
1983 Honda V65
1979 Yamaha XS1100
1977 Honda CB750
1963 Harley Duo Glide
1965 Honda 305
1962 Honda Cub 50
1960 Cushman scooter
Was I being naughty...officer?
retiredjj is offline
post #9 of 9 Old Nov 4th, 2008, 6:02 pm
mwnahas's Avatar
Re: Shock life....
Pretty much what others have said. My 03 shocks were totally gone by 30K. I as able to revive or extend the rear shocks a bit at 25K by adding preload oil, but the front was gone by 30K.
Just Go
Cleveland Ohio
mwnahas is offline
HyperPro Group Buy - Here It Is! deputy5211 Bike Talk 73 Jan 2nd, 2010 4:40 am
Suspension.....(again!!!....sigh) PhillWard Australia, New Zealand, and AsiaPac 26 Nov 13th, 2006 10:38 pm
Stock Shock Life Expectancy? space_coast_lt K1200LT 31 May 3rd, 2006 9:30 am
Replacement of rear shock suspension unit PhillWard Australia, New Zealand, and AsiaPac 3 Jan 17th, 2006 5:01 pm
