brakes - BMW Luxury Touring Community
post #1 of 4 Old Oct 25th, 2008, 3:29 pm Thread Starter
POJ
POJ's Avatar
brakes
On my ride into work this mornin I had a couple of brake failures( both red lights flashin) and my cruse control would not operate. Anybody seen this before?
POJ is offline
post #2 of 4 Old Oct 25th, 2008, 3:51 pm
Re: brakes
For an 02 & newer, top off the brake fluid in the forward half of the rear reservoir.
Morley is offline
post #3 of 4 Old Oct 26th, 2008, 1:05 pm
Re: brakes
Flashing brake lights are most often caused by low fluid level in the rear reservoir. The '02 and newer LTs are very sensitive to this, and should be topped up all the way to the Max mark in both chambers.
The second most common cause is a low battery. Either a temporarily low charge state, or possibly a cell starting to go bad.
But since you said you also saw cruise control problems, I'd look at the front and rear wheel ABS sensors. Clean them well, and check both for proper gap. Also, look for a possibly damaged sensor wire, maybe even an intermittent fault.
Good luck, and let us know what you find.
post #4 of 4 Old Oct 29th, 2008, 6:28 pm Thread Starter
POJ
POJ's Avatar
Re: brakes
Thank you guys
POJ is offline
Do your brakes click markbreen K1200LT 20 Apr 2nd, 2012 10:35 pm
Brakes sometime dont work Vince_nj1 K1200LT 3 Jun 2nd, 2008 8:50 pm
Confused about covering my brakes RTrev Bike Talk 32 Apr 27th, 2008 5:20 pm
Haul Road and EVO brakes jkersh1 Bike Talk 26 Mar 30th, 2007 11:04 pm
Power brakes: TOO sensitive? dshealey K1200/1300GT (The Next Generation) 6 Sep 29th, 2006 2:24 pm
