Clutch - K12LT - BMW Luxury Touring Community
post #1 of 13 Old Oct 22nd, 2008, 1:49 pm Thread Starter
Question Clutch - K12LT
Is there a way to adjust clutch travel?
thanks
Pjmatz is offline
post #2 of 13 Old Oct 22nd, 2008, 5:38 pm
motorman587's Avatar
Re: Clutch - K12LT
I am not wrench head, but it is a hydraulic, and the only thing that you can adjusts is the clutch lever for finger reach...........I could be wrong.
Florida
2004 BMW R1150R Black
motorman587 is offline
post #3 of 13 Old Oct 22nd, 2008, 6:26 pm
Axle's Avatar
Re: Clutch - K12LT
nope you are spot on not adjustable
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #4 of 13 Old Oct 22nd, 2008, 6:33 pm Thread Starter
Re: Clutch - K12LT
Thanks to both
Pjmatz is offline
post #5 of 13 Old Oct 23rd, 2008, 7:50 am
Re: Clutch - K12LT
,,,,,,,,,,,,,,,,,,, why, specifically, do you ask if the clutch is adjustable...?
It is operated hydraulically... like your brakes... if your clutch is not fully disengaging you could have air in the line or a failing master or slave(more likely)..
J.M.J...
Dcn Channing
post #6 of 13 Old Oct 23rd, 2008, 8:44 am Thread Starter
Re: Clutch - K12LT
No issues with disengagement, the clutch itself works properly.
I was trying to reduce the clutch lever travel, the clutch engagement is too far out; and i thought it was possible some kind of adjustment to bring it (engagement) more close in.
Paulo
Pjmatz is offline
post #7 of 13 Old Oct 23rd, 2008, 8:45 am
Re: Clutch - K12LT
I have "adjustable" levers on my '05 LT..
Do you? It's a little wheel on the lever with numbers.
J.M.J...
Dcn Channing
post #8 of 13 Old Oct 23rd, 2008, 10:08 am Thread Starter
Re: Clutch - K12LT
I do have adjustble levers, even ajusting the clutch one to the closest position to the hand grip, still is way far the clutch engagement.
Paulo
Pjmatz is offline
post #9 of 13 Old Oct 23rd, 2008, 10:32 am Thread Starter
Re: Clutch - K12LT
May be there is an adjustment
Check sketch in below site - screw No 13 could the adjustment
http://www.realoem.com/bmw/showparts...29&hg=32&fg=10
Pjmatz is offline
post #10 of 13 Old Oct 24th, 2008, 8:34 am
razman10's Avatar
Re: Clutch - K12LT
Originally Posted by Pjmatz
...the clutch engagement is too far out; and i thought it was possible some kind of adjustment to bring it (engagement) more close in.
I think that is by design. I remember reading on here something about shifting to just barely squeeze the clutch to shift. Pulling it all the way in is not needed as it is on other bikes.
Found it: http://www.bmwlt.com/forums/showthread.php?t=26239
Good info...
__________________
Ray "Razman"
2004 BMW K1200LTE - Rosie (As in Whole Lotta Rosie)
1996 HD Sportster XLH883 Hugger (sold)
1986 Honda Interceptor VF500F (sold)
Your chosen perspective changes everything. - Unknown Author
"You are what you repeatedly do. Excellence is not an event - it is a habit." - Aristotle; 384-322 BC, Greek Philosopher and Scientist
razman10 is offline
post #11 of 13 Old Oct 24th, 2008, 10:02 am
Re: Clutch - K12LT
It could be.. just remember.. the clutch Master Cylinder needs a certain amount of "travel" to move enough fluid to disengage the clutch. Also, when "released" you need a little play so that the fluid in the hose can be fully released. Any residual pressure will keep the Slave engaged with the throwout bearing... not good.
If it is really an issue, perhaps you can see if someone here has a "spare" clutch lever off a parted-out (breaker) bike. Take the lever to an aluminum(alumi-ni-yum) shop and have them cut the lever and weld at a closer angle. Be sure to sketch an outline on paper so you know how far you can "move" it toward the handlebar.
J.M.J...
Dcn Channing
post #12 of 13 Old Oct 24th, 2008, 1:15 pm Thread Starter
Re: Clutch - K12LT
I understand,
Paulo
Pjmatz is offline
post #13 of 13 Old Oct 24th, 2008, 7:59 pm
dmatson's Avatar
Re: Clutch - K12LT
The only time i use the clutch any more is to take off and down shift. My LT up shifts very smooth, even better than using the clutch.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
Take off, 'eh? Starting the LT from stop... petevandyke K1200LT 26 May 30th, 2012 9:48 am
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 10:19 am
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 9:00 pm
