valve inspection - BMW Luxury Touring Community
post #1 of 9 Old Oct 19th, 2008, 8:54 pm Thread Starter
davek1's Avatar
valve inspection
Where is a good place to get instructions for checking valve clearances, adjustments and throttle body adjustments.
I read once that someone had an instructional dvd for sale.
I am semi mechanically inclined, but "for dummies" directions would be good for me.
davek1 is offline
post #2 of 9 Old Oct 19th, 2008, 9:30 pm
Re: valve inspection
www.gunsmoke.com , go to K1200RS page, valve adjustment (valve adjustment same as for LT engine). Only change: do NOT remove sparking plugs before checking valve gap.
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #3 of 9 Old Oct 20th, 2008, 9:22 am
razman10's Avatar
- Bob
Newbie question - why not remove the spark plugs, and why does gunsmoke recommend that they should be removed?
__________________
Ray "Razman"
2004 BMW K1200LTE - Rosie (As in Whole Lotta Rosie)
1996 HD Sportster XLH883 Hugger (sold)
1986 Honda Interceptor VF500F (sold)
Your chosen perspective changes everything. - Unknown Author
"You are what you repeatedly do. Excellence is not an event - it is a habit." - Aristotle; 384-322 BC, Greek Philosopher and Scientist
razman10 is offline
post #4 of 9 Old Oct 20th, 2008, 10:55 am
That is one thing that the Gunsmoke had very, very wrong. Ufortunately, I have not been able to find a way to contact the author and have him change it.
It is specifically stated in the BMW service manuals that the spark plugs should NEVER be removed before checking valve clearances.
The reason is that removing spark plugs usually dislodges small flecks of carbon, which could fall down into any open exhaust valves on the LT engine. Then when checking the clearances the valves could close on this material causing the clearance reading to read higher than is real. This could cause one to think that the clearance is good, or too large, and as soon as the engine is started the debris would be blown out and the clearance would be smaller by the thickness of the debris. Remember, the clearance tolerance is less than the thickness of a piece of paper, so something that thick or more between the valve and seat could cause a very wrong reading.
post #5 of 9 Old Oct 20th, 2008, 12:58 pm
razman10's Avatar
I see (said the blind man, as he picked up his hammer and saw...) It makes sense.
So then there is no purpose whatsoever for removing the plugs for a valve check. Do they need to be removed if an adjustment is needed?
__________________
Ray "Razman"
razman10 is offline
post #6 of 9 Old Oct 20th, 2008, 1:07 pm
Paul Sayegh's maintence video's do go through checking valve clearances. It also stresses not to remove the spark plugs. His video does not go through the actual adjustment procedure, should that be necessary.
jrlakin is offline
post #7 of 9 Old Oct 20th, 2008, 3:10 pm
No need to remove the plugs for any reason except to change them. If not changing the plugs, then leave 'em in. We don't gap or clean them, just change them periodically.
post #8 of 9 Old Oct 20th, 2008, 9:08 pm
ErnieA's Avatar
I believe his thinking was the engine would be easily rotated without the compression. Thus making the job of placing the cams in position over the valve buckets, for measuring, much easier. David is 100% correct that flakes of carbon can be dislodged from the plugs and fall between an open seat and the exhaust valve surface whice can make for a false measument.
I replace the plugs every 50k, therefore in 5k miles I'll be installing my 3rd set.
Ernie A
Milwaukie, OR
2013 R1200GSW
> 28k miles!
ErnieA is offline
post #9 of 9 Old Oct 21st, 2008, 9:06 am
razman10's Avatar
David & Ernie,
Thanks for your insight!
(I love this place! )
__________________
Ray "Razman"
razman10 is offline
Simple valve adjustment CharlieVT K1200LT 4 Jun 19th, 2008 8:41 pm
Don't Wiggle the Valve! wardenross K1200LT 11 Sep 5th, 2007 5:11 pm
valve clearance inspection HowardRichman K1200/1300GT (The Next Generation) 14 Aug 23rd, 2007 6:11 am
The Scphincter Valve DaFlake Humor 1 Apr 6th, 2006 12:46 pm
