Would 2005 Front/Rear wheels fit 1999 LT? - BMW Luxury Touring Community
post #1 of 6 Old Oct 19th, 2008, 10:35 am Thread Starter
Are all LT models using the same rear and front wheels? Would 2005 LT Front/Rear wheels fit a 1999 LT?
Alpac is offline
post #2 of 6 Old Oct 19th, 2008, 3:28 pm
BecketMa's Avatar
Re: Would 2005 Front/Rear wheels fit 1999 LT?
I use this site to look up parts:
http://www.maxbmwmotorcycles.com/fiche/fiche.asp
If I remember correctly, the rims are the same.
Bob 0h 0h LT
BecketMa is offline
post #3 of 6 Old Oct 19th, 2008, 4:02 pm
®win's Avatar
The '99 - '03 LT has a different ABS ring than the newer model. AFAIK the front wheel rim is not interchangeable.
Erwin
R1200GS Adventure LC 2018, Blackstorm/Schieferdunkel Matt/Achatgrau (Triple Black), in full options, BMW Navigator V
R1200GSA LC '18 <- R1200GSA LC '14 <- K1600GTL '12 <- R1200GS Adventure '09 <- K1200GT '07 <- K1200LT '05 <- K1200LT '99 <- K1100LT '95 <- K75RT '92
®win is offline
post #4 of 6 Old Oct 19th, 2008, 5:00 pm
Agreed. The ABS ring mounts on the brake disk standoffs on one side, under the rotor. The older and newer ABS rings are different thicknesses. So to compensate, the brake disk standoffs are different lengths. So I believe that either wheel will bolt up to any year LT, but the rotor will be in a slightly different position which would most likely cause brake rubbing problems.
I think the rear wheels are basically interchangeable though.
post #5 of 6 Old Oct 19th, 2008, 8:40 pm Thread Starter
THANKS
Alpac is offline
post #6 of 6 Old Oct 23rd, 2008, 7:53 pm
Ron_Kendall's Avatar
Correct, the stand offs on the front rims are a different length...1/8" longer on 2004 & newer...I found this out when I purchased some rims from a forum member that had them for sale...So I gave the front rim to my son who has access to a table grinder & had him grind off the 1/8"....The rear rims are interchangeable.
~ron~
"00 K1200LTC
"99 R1200C
"?? Indian Scout
"02 Uni-Go
"If you always tell the truth, you never have to remember anything"
Ron_Kendall is offline
Does Post 2005 BMW K1200LT Logo Emblem fit Pre 2005 models? MattKas K1200LT 1 Jan 27th, 2008 3:33 pm
Metzler 880 vs. BT020 debate on 2005 and up Crestwood330 Tires 16 Dec 16th, 2007 7:17 pm
Remus exhaust on a 1999? coug66 K1200LT 3 Aug 18th, 2007 8:15 am
2005 or 2007, servo or non servo dand2 RT Series 14 Aug 8th, 2007 8:45 am
Second Set of Wheels - Great Deal Ted Shred GS Series 0 Nov 6th, 2006 2:52 am
