3 year/30,000 km annual service - BMW Luxury Touring Community
post #1 of 11 Old Oct 14th, 2008, 8:40 pm Thread Starter
RealWing's Avatar
Took my bike to dealer today for annual maintenance and to address some warranty issues. Current mileage is 33237 km (~20,700 miles)
1. Had the brake wheel circuits flushed and a bleed test as per annual requirement. Fluid was very clean. A copy of the bleed test is attached for info. This was the only work I had the dealer perform. I will do all the other annual checks. Cost was $233.86 Can.
Note: BMW has issued a Bulletin dated Nov 2007 that specifies that the ABS Control Circuits can be flushed every 4 years - as opposed to every 2 years on the Maintenance Schedule.
The following work was all done under warranty:
2. I had 2 of the chrome strips (p/n 51-13-7-699-569 and 571) replaced on the outlet from the cooling port. The chrome had started to come unglued as shown in the attached photo.
3. The exhaust mounting bracket (p/n 18-21-7-656-032) had fractured and was replaced . See photo.
4. I noticed some looseness on my rear wheel this summer - but did not appear the be the rear drive. When I showed the dealer - they said it was the paralever needle bearings. The bearings were replaced (I thought these would not be covered by warranty but they were!!).The bearing p/n was 33-17-2-311-091.
Name:	Bleed Test comp.jpg
ID:	20063   Click image for larger version
ID:	20064   Click image for larger version
2015 K1600GTL
1970 Plymouth Superbird 440-6bbl
1969 Plymouth Barracuda Fastback 340-auto
1969 Plymouth Barracuda Convertible, 6.1 L SRT8 Hemi transplant
RealWing is offline
post #2 of 11 Old Oct 14th, 2008, 9:27 pm
Re: 3 year/30,000 km annual service
Great Jim,
I had wondered what was done on the bleed test. Quite a pressure difference between input and output. I have to agree on the bulletin for the control circuits. I have never seen any dirty fluid come from there unlike the wheel circuits which are usually pretty dark after a year.
I finally got a chance to drill my weep hole and I also had worn paralever bearings (44K). One was quite visible and the other just felt "notchy". I had a set of the J&L oiltite bronze units so that is what I installed when it went back together. They use a little less pre-load compared to the stock needle bearings. Will see how they wear.
Guess I'll keep an eye on my banjo fitting for the exhaust.
post #3 of 11 Old Oct 15th, 2008, 9:37 pm Thread Starter
RealWing's Avatar
When I got home, I checked the rear wheel and to my dismay, the rear wheel is still loose - probably a bit worse than before!! ( I should have checked it at the dealer before I left for home) The looseness is definitely in the paralever bearings - so it will have to go back to the dealer again.
2015 K1600GTL
RealWing is offline
post #4 of 11 Old Oct 15th, 2008, 10:24 pm
Mugszy's Avatar
Had same issue with the chrome pieces except that all four were replaced. Also replaced rear disk. Now I have issues with the centre stand not wanting to get the bike to sit up on first attempts and my trunk mirror broke but I am not sure if that is covered under warranty.
Which dealer did you use? I have nothing good to say about Wolf.
You may be interested in a tech session I am holding this Sat. (check out my thread under our flag), hope you can attend.
Regards...
Mugz
BMWMOA - #45711
2006 K1200LT - Blue Baby
2003 R1150GS - Yellowbird
1981 R100CS - Sadly gone
1986 K100RS - In the past
Mugszy is offline
post #5 of 11 Old Oct 16th, 2008, 3:46 pm Thread Starter
RealWing's Avatar
Regards...
Mugz
I use Open Road in Newmarket. Have been very pleased with service and knowledge of mechanics and Service Manager.
I had seen your post about the Tech session. If I come - I'll bring my GS911 Code Reader - unless someone already has one?
Jim
2015 K1600GTL
RealWing is offline
post #6 of 11 Old Oct 16th, 2008, 6:08 pm
Mugszy's Avatar
Jim
Hope you can make it!
Mauro
BMWMOA - #45711
Mugszy is offline
post #7 of 11 Old Oct 31st, 2008, 7:41 pm Thread Starter
RealWing's Avatar
I took the bike back again today and the problem turned out to be the RH side paralever bearing. One of the needles had been pushed out of the plastic retainer in the cage and was jammed behind it.
It was damaged during the last replacement on Oct 14th due to improper assembly - as the rear drive was being positionned.
All is now well!!!
2015 K1600GTL
RealWing is offline
post #8 of 11 Old Oct 31st, 2008, 9:12 pm
Mugszy's Avatar
Jim
My bike is at Open Road for the centre stand, trunk mirror, and brake fluid change. They have had it for over a week with no word from them but I assume parts need to be ordered, so it takes time.
Mauro
BMWMOA - #45711
Mugszy is offline
post #9 of 11 Old Oct 31st, 2008, 10:25 pm
Hey Mugz, I bought my 2005 at Wolf, got a good deal, enjoyed the whole buying experience, and they have been great so far for service. Why are you not happy with them?
2005 K1200LT
1980 Kaw KZ1300
dmacd is offline
post #10 of 11 Old Nov 1st, 2008, 8:17 am
Mugszy's Avatar
Wolf has been known to cater to their own customers and I have heard good things about Ian's mechanical skills, indeed they are only 45 minutes away but they do not like you not buying from them and expect to be serviced in any decent amount of time. I bought my bike privately, my centre stand was acting up and they wanted to keep my bike overnight to inspect it. I do not have means to get back home but they refused to look at it while I was there saying they could not afford to pull a mechanic to take a look. I guess it takes a long time to press a button to see if the stand would deploy. Asked if I could rent a ride... nope, only do that for customers that bought the bike their... so he realy does not exude confidence that he wanted to do warranty work on my bike.
I cannot tell him how to run his business but I do not understand why he wants to turn away customers.
Mugz
BMWMOA - #45711
Mugszy is offline
post #11 of 11 Old Nov 1st, 2008, 9:50 am Thread Starter
RealWing's Avatar
Mauro
Say it there yesterday. Ronn was working on the center stand. Said the diagnostics could not communicate with the controller. may need a whole new assembly.
Jim
2015 K1600GTL
RealWing is offline
Sloppy service from Leo's South in MSP pushin9s Dealer Experiences 14 Sep 3rd, 2009 9:31 am
12,000 and Annual Service at the same time nctarheels K1200LT 9 Oct 10th, 2008 12:07 pm
Service NOGILLS2 Humor 1 Aug 5th, 2007 10:36 pm
Annual and 36k service costs $2020 ? msmckinley Northern California 14 May 10th, 2006 4:39 pm
