Differential SEAL failure ..... - BMW Luxury Touring Community
post #1 of 12 Old Oct 14th, 2008, 12:39 am Thread Starter
motorhead's Avatar
I finally picked up my diff rebuild parts last week and got into the bike Sunday.
Removing the differential assembly was easy enough, as was taking it apart.
** Whats odd was the seal had leaked halting my vacation trip 50 miles from home a few weeks ago, but thats it !! .....
Upon inspection after disassemble, there was NOTHING wrong with the crown bearing, retainer fully intact and smooth as silk rotation with no ball fretting ..... WTF ?
Found no nick in seals lip, no string wound up around it, no obvious reason why the seal allowed the oil out ?
Anyways, pulled off the old bearing and seal replacing them. At 42K+ figured it was a good preventative measure.
Talk about missing a bullet .... but still dead, life's odd that way
Name:	S & D 2008 Vacation 275.jpg
ID:	20046   Click image for larger version
Name:	S & D 2008 Vacation 276.jpg
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #2 of 12 Old Oct 14th, 2008, 5:49 am
RocketRon's Avatar
Re: Differential SEAL failure .....
Sure would make a tight right hander a little scary!
Good job!
RocketRon is offline
post #3 of 12 Old Oct 14th, 2008, 3:38 pm
Any oil seal is subject to failure at any time - just luck of the draw.
post #4 of 12 Old Oct 14th, 2008, 4:45 pm
BMW Guru
Ted Shred's Avatar
Thanks for the update. Glad it was a relatively easy fix.
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #5 of 12 Old Oct 14th, 2008, 5:18 pm
motorman587's Avatar
Looks like my rear tire a couple of days ago................Glad all is well.
Florida
2004 BMW R1150R Black
motorman587 is offline
post #6 of 12 Old Oct 14th, 2008, 8:10 pm
Glad it is going good for you.
Just a bit of information for future knowledge. The final drive is not a differential. It is only a right angle drive unit. A differential has "spider" gears driving two individual axles in a four wheel vehicle to allow the two tires to rotate at a "differential" speed when turning. Otherwise, one or both tires would have to slide around the turn. When only one wheel is involved, no differential drive is needed.
post #7 of 12 Old Oct 14th, 2008, 9:36 pm
hallzee's Avatar
Scott,
Glad it all came together!
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #8 of 12 Old Oct 14th, 2008, 11:18 pm Thread Starter
motorhead's Avatar
Error in my obvious ignorant naming of said part .... error noted
*** Trailer Too ***
T
wisties Required
post #9 of 12 Old Oct 15th, 2008, 6:54 am
CharlieVT's Avatar
Even the BMW parts fische viewable on Max and A&S BMW's website refers to the "differential gear set" components of the final drive so it is easy to understand how the term "differential" gets used by folks here rather than the term "final drive" when referring to the assembled unit. I wonder if the "crown wheel" used in our final drive isn't the same part used in some differentials in other applications.
CharlieVT is offline
post #10 of 12 Old Oct 15th, 2008, 7:05 am
rattler50's Avatar
If you hadn't stopped when you did, you might have had an FD failure and blamed it on the bearing.......Mine was just the opposite, the FD failed and the seal didn't leak. Good think your seal dumped enough for you to see............
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #11 of 12 Old Oct 15th, 2008, 3:55 pm
Since the gear ratio isn't 1:1, the output is turning at a different speed than the input so it is still a "differential" drive in a sense.
Sorry, I couldn't resist.
post #12 of 12 Old Oct 15th, 2008, 4:16 pm
zippy_gg's Avatar
The final drive seal was going out on my 05, and replaced under warranty before it got to leak as much as yours.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
LT Main Seal Failure/Clutch Failure 9771 K1200LT 15 Jun 2nd, 2010 8:55 pm
Tranny seal failure question joevano K1200LT 5 Jan 24th, 2008 9:24 am
Seal Failure Question GWBMW K1200LT 6 Oct 30th, 2007 8:05 am
Shaft seal pulling made easy Schweintechnik K1200LT 4 Aug 6th, 2007 6:21 pm
Tranny output shaft seal failure. Gene_Chapman K1200LT 15 May 21st, 2006 2:09 am
