Fuel Leak (Disconnect) - BMW Luxury Touring Community
post #1 of 6 Old Oct 13th, 2008, 4:41 pm Thread Starter
WAL
WAL's Avatar
Unhappy Fuel Leak (Disconnect)
I have a fuel leak at the disconnect. This was supposedly done as a recall on a 12K service. I think it is just the "o" ring on the pressure line. My question is about the other line that comes from the tank when I disconnected it fuel was pouring out. Is this normal or should this have been blocked off by a check valve when the line was disconnected? I have the line pinched off right now. Thanks for your help in advance.
WAL is offline
post #2 of 6 Old Oct 13th, 2008, 5:10 pm
zippy_gg's Avatar
Re: Fuel Leak (Disconnect)
When you disconnect the line with a QD the fuel should NOT flow. If it does then you know there is an issue with the QD (and it is definitely NOT the o-ring since you are disconnected) or a cut in the line.
Another possibility is that one of the QDs was mounted backward, most likely the one letting fuel flow when disconnected.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 6 Old Oct 13th, 2008, 7:10 pm Thread Starter
WAL
WAL's Avatar
After posting this I went back out to look at the disconnects again and found that one is broken. I guess that I will be replacing both with metal ones as soon as I can find out where to get them. Thanks for your reply.
WAL is offline
post #4 of 6 Old Oct 13th, 2008, 7:16 pm
Beemer Bone Yard has them. Just did the install recently. Good people to deal with. Quick delivery.
rcockrum is offline
post #5 of 6 Old Oct 13th, 2008, 7:22 pm Thread Starter
WAL
WAL's Avatar
Are the ones from Beemer Boneyard metal and what is the cost? Thanks for your reply.
WAL is offline
post #6 of 6 Old Oct 13th, 2008, 8:46 pm
AlaskaFish's Avatar
Wink Re: Fuel Leak (Disconnect)
If you search this site for "quick Disconnects" you will get a ton of info on them. Here is just a sample:
http://www.bmwlt.com/forums/showthread.php?t=31646
or here:
http://www.bmwlt.com/forums/showthread.php?t=32304
or here:
http://www.bmwlt.com/forums/showthre...smallparts.com
(I went with the Smallparts.com ones myself also!)
Should be plenty of pickings in those threads!
HTH,
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
2004 R1150rt Fuel Leak... kuiama RT Series 8 Dec 14th, 2011 11:16 pm
fuel line quick disconnect tbl160 K1200LT 4 Sep 19th, 2007 10:47 am
Mystery Fuel Leak old1951 K1200LT 6 Aug 3rd, 2007 8:37 am
1999 fuel leak piusg K1200LT 3 Jul 26th, 2006 1:29 pm
