Loud clunk when applying front brake - BMW Luxury Touring Community
post #1 of 8 Old Oct 13th, 2008, 4:07 pm Thread Starter
Hi Guys, has anyone else experienced a knocking from the front end when braking. It almost feels as though there is excessive play on the caliper/disc.
I had a quick look but could feel nothing wrong, i will investigate further at the weekend, but thought i would drop a quick post on this superb forum, and see if any of you clever chaps have experienced this before.
jmech is offline
post #2 of 8 Old Oct 13th, 2008, 5:13 pm
c00k1e's Avatar
Re: Loud clunk when applying front brake
Whatcha, the only thing I can think of is a loose caliper bolt or the rotors are floating a bit too much. The wavy washers eventually stiffen and need replacing (a bit of a pain as the bolts that hold them on are pre-thread-locked, need replacing and cost a bit more than expected).
If the latter, I have ridden for a while on them like that with no problem but an annoying increase in sound when on rough roads.
c00k1e is offline
post #3 of 8 Old Oct 14th, 2008, 7:16 am
joegottberg's Avatar
It may not be too bad.
Since the disc "floats" a little and the rivets wear a little, things can "shift" (a little) when brakes are applied.
The other thing is the pads can shift in the caliper. Overall makes it sound worse than it is.
But be 100% sure your caliper is tight.
If the bolts are tight, wiggle the pads and disc and you'll likely see your problem.
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #4 of 8 Old Oct 14th, 2008, 10:29 am
It could knock once when the pads hit the rotors, if that's the case its normal on the servo-assisted LT. If its knocking multiple times then it definitely needs to be looked at.
Caveno is offline
post #5 of 8 Old Oct 14th, 2008, 3:29 pm Thread Starter
Thanks guys, i have just checked and it appears to be the disc floating too much. Would you recommend changing the bolts or washers..or just live with it. Thanks again.
jmech is offline
post #6 of 8 Old Oct 15th, 2008, 7:54 am
razman10's Avatar
If it ain't broken... Don't fix it!!!
__________________
Ray "Razman"
2004 BMW K1200LTE - Rosie (As in Whole Lotta Rosie)
1996 HD Sportster XLH883 Hugger (sold)
1986 Honda Interceptor VF500F (sold)
Your chosen perspective changes everything. - Unknown Author
"You are what you repeatedly do. Excellence is not an event - it is a habit." - Aristotle; 384-322 BC, Greek Philosopher and Scientist
razman10 is offline
post #7 of 8 Old Oct 15th, 2008, 8:28 am
c00k1e's Avatar
Keep going till it just gets too embarrassing to live with. When that day comes you have to change all bolts and washers at once. It may be a good idea if you do that when you exchange the pads.
c00k1e is offline
post #8 of 8 Old Oct 15th, 2008, 12:45 pm
dukey33's Avatar
On bikes with regular telescoping forks, if the front end clunks when braking, it can be an indication of the head stem bearings getting loose.
I can't really speak to the integrity of the LTs front suspension since I haven't delved into its design eccentricities yet, but it may be worth taking a look to verify all is well up there.
-2000 K1200LT
dukey33 is offline
Front Brake interupting Radio kpwrig K1200LT 1 Jun 16th, 2008 10:32 am
Front right brake Colin1952 K1200LT 8 May 1st, 2006 7:06 am
Is it OK just to use front brake only? JoyfulSoul K1200LT 62 Mar 5th, 2006 8:03 pm
Front Brake Lever Issue Jerrod Maguire K1200LT 2 Jan 20th, 2006 11:49 pm
Front Brake Rotor Bolts Daman858 K1200LT 8 Oct 7th, 2005 4:19 pm
