Radio Issue - BMW Luxury Touring Community
post #1 of 5 Old Oct 13th, 2008, 9:25 am Thread Starter
EzyMount's Avatar
Radio Issue
ANother confirmation that radio is causing excessive battery drain, in this case. While searching for battery drain, I finally pulled fuse for Radio Circuit, which resulted in 0-drain overnight, as compared to appx 1V drain overnight while connected, as measured several nights in a row...
Anyone seen this before ?
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #2 of 5 Old Oct 13th, 2008, 10:08 am
Re: Radio Issue
If the steering lock isn't on, the radio has power, so it can in theory use up power. I don't think thats causing your battery to drain though. If you put the steering wheel lock on does the battery still drain?
Caveno is offline
post #3 of 5 Old Oct 13th, 2008, 2:53 pm Thread Starter
EzyMount's Avatar
Re: Radio Issue
did not seem to make a diff ! based on the way the radio has been acting latey, on/off, inconsistent speaker responses, etc. I believe my radio is toast and needs to be replaced. unless the connectors under my stingray need attention ?
Retired to NC !
EzyMount is offline
post #4 of 5 Old Oct 13th, 2008, 9:55 pm
AlaskaFish's Avatar
Red face Re: Radio Issue
Jim, sounds strange, but possible I guess. I do know that the '99 and some early '00 LT's supposedly had a problem with the radios running down the batteries, but it seems you would have seen this long ago!
If you are sure it is the radio, and can't find one anywhere else, drop us a PM since we do have one from a '00 LT that we would be willing to part with. The one we have is the Radio/Cassette version.
Good Luck!
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #5 of 5 Old Oct 14th, 2008, 1:38 pm
Re: Radio Issue
What happens when you pull the fuse on the radio?
The radio may be draining your battery, but the problem may not be the radio. The radio shouldn't have any power in the first place, it may be a wiring problem. You could also disconnect the radio and hook up a multimeter to it, see if the radio is getting power when it shouldn't.
Sounds like a fun problem to solve, wish I had this problem An excuse to take her apart!
Caveno is offline
Radio issue Travis K1200LT 4 Aug 13th, 2008 11:03 pm
Radio Reception in NJ and First Gear Issue sully2028 K1200LT 1 Apr 7th, 2008 10:17 pm
A New Radio Problem? RVB1019 K1200LT 7 Sep 3rd, 2007 6:55 pm
Need help debugging radio issue hd2bmw Bike Talk 6 May 2nd, 2007 6:28 pm
Help with strange Radio issue hd2bmw K1200LT 1 Apr 20th, 2007 4:40 pm
