Abs Module - BMW Luxury Touring Community
post #1 of 7 Old Oct 12th, 2008, 5:50 pm Thread Starter
Abs Module
Hi I have a faulty abs module, im looking to fit a second hand one but am told by my local bm dealer that its not possible as they are locked digitaly to the vin no, can anyone tell me if this is correct or can it be unlocked.
cheers nige.
nige-h2008 is offline
post #2 of 7 Old Oct 12th, 2008, 6:14 pm
grahamw's Avatar
Re: Abs Module
Nigel
I strongly suspect the dealer is talking crap. Phone Motorworks and see if the have a used one and they will know if you hVE TO DO ANYTHING ELSE.
Regards
Graham Wintersgill
2001 K1200LT
1995 K75RT now deceased
grahamw is offline
post #3 of 7 Old Oct 13th, 2008, 11:20 am
hmmmm90s's Avatar
Re: Abs Module
utter crap - at least as far as my year 2000 ABSII model.
i replaced the unit myself and the replacement unit has never been on a dealer computer and works fine.
someone is engaging in FUD.
g.
greg shamieh boof # 93 k-whiner # 83
jefferson, maryland
2000 K1200LT --- "darkside"
75R90S -- "esssss"
73R75/5 -- "mojo"
hmmmm90s is offline
post #4 of 7 Old Oct 13th, 2008, 11:23 am
kevincook's Avatar
Re: Abs Module
What exactly is the problem? Have you tried completely flushing the system with new fluid? Many have reported success with a complete flush.
Good Luck,
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #5 of 7 Old Oct 13th, 2008, 4:05 pm Thread Starter
Re: Abs Module
Hi All machine is registerd 2001 done 21k, bought machine in june with a temp fault on abs, system will re-set (switch off-on ignition etc) but after you use brakes warning lights come on brake failure steady and abs light blinks slowly system is integral abs.
Have done a full brake fluid change done by Motorad Edinburgh it was here they said abs unit was faulty and needed replaced at £1200 + labour picked me up off the floor with that one. Was told by motorad that would have to be a new unit and could not fit any other supplied parts???as unit is locked out to vin No so wont work on the moditec bleed system and Clymer manuals say take to dealer to have system bleed tested etc etc so next step is contacting motoworks see if they can throw anymore sugestions into the pot will let you know what they say
thanks all for the input nige.
post #6 of 7 Old Oct 13th, 2008, 4:31 pm
BecketMa's Avatar
Re: Abs Module
I could be that they do not want the responsibility of buying and installing a used unit.
Just ask 'em if you need to have the old VIN plate cut off the bike you buy the used part from and then glued to the side of the ABSII? You'll probably get a laugh on the look on their face and laugh even more with their answer!
BecketMa is offline
post #7 of 7 Old Oct 14th, 2008, 12:38 pm
grahamw's Avatar
Re: Abs Module
Nige
i had a similar 'lights' situation that started just after changing my tyres. It turned out I had knocked one of the sensor rings slightly. It might be worthwhile carefully checking the sensor gap.
I can see the Moditec brain being tied to the VIN but the pump is just that.
Regards
Graham Wintersgill
2001 K1200LT
grahamw is offline
It works!!! - ABS 2 fault reset (long) BDC K1200LT 114 Nov 24th, 2018 6:17 pm
ABS unit gone again plonk K1200LT 9 Jun 17th, 2011 4:06 am
