old harness no alarm, new harness has alarm - BMW Luxury Touring Community
post #1 of 7 Old Oct 12th, 2008, 3:58 pm Thread Starter
Was just reading about alarms and working without alarm. The new harness I just installed had an alarm where my bike came without an alarm. How can I make this work? I have not tried to start yet but sounds like it is going to shut fuel and starter. How do I bypass the alarm part of harness??? Thanks
todrut is offline
post #2 of 7 Old Oct 12th, 2008, 5:28 pm
Re: old harness no alarm, new harness has alarm
Todd,
It depends on the year model your harness came from but we have worked out the bypass procedures for all of them. The earlier ones are easiest but they are all do able. My version (05 and up)is posted in the "Files" "Technical" section.
Oh wait you are the guy that had the melted harness - I remember that.
Try this out.
post #3 of 7 Old Oct 12th, 2008, 7:23 pm Thread Starter
Melted harness is an under statement to what it did now. It happened about 3 weeks after you came up. The poor bike has been sitting since then. Finally found a 10/2000 harness for 200.00 and bought it. My bike is 01/2000
Is there anything that tells what screws go where? I'm about ready to put back together and trying to remeber long screws/short torx screws, allen head long and short. Sure hope I'm doing it right.... Had a good teacher...
todrut is offline
post #4 of 7 Old Oct 13th, 2008, 7:01 pm
On the Torx - easy way to tell is that if it goes into a well nut (rubber / brass) it is a long one. If it is going into a threaded steel panel or clip nut it can be the short ones.
post #5 of 7 Old Oct 13th, 2008, 10:31 pm
sparky_k1200lt's Avatar
Originally Posted by jzeiler
Try this out.
John beat me to it.... That was my write-up, for a 2001 LT (10/2000 mfg.)
If you are installing a new harness, you might be able to adjust the connections to the starter relay and fuel pump, so that the harness will not feed the wires back to the alarm area. Do a search for the install instructions for the alarm (as a dealer addition), and you'll see what wires were affected by the installation. Or, it might be easier to do the by-pass as I described.
...Bob
1978 GL1000
sparky_k1200lt is offline
post #6 of 7 Old Oct 14th, 2008, 3:39 pm
Sorry Bob - meant to give you credit for it.
post #7 of 7 Old Oct 14th, 2008, 11:42 pm
My write-up with photos is here
The anti-theft system has 2 switches/relays (or equivalent) that go inline with the starter button and the fuel pump. When armed, both are open, meaning the starter button won't work and the fuel pump won't work. When disarmed, they work as normal.
...Bob
1978 GL1000
Help! Alarm fuse F3 keeps blowing sparky_k1200lt Batteries, Chargers, & Electrical 3 May 6th, 2013 7:44 pm
HELP! Alarm went off now bike won't start! blavenia K1200LT 12 Jul 22nd, 2009 10:33 am
Help! Alarm Smoked, Killed bike, 2001 LT Wood614 K1200LT 9 Jun 1st, 2008 8:36 am
Possible Alarm Solution Jinks K1200LT 3 May 26th, 2007 9:18 pm
New Alarm Fob for 2003 Dean_BMW K1200LT 0 Nov 23rd, 2005 8:11 pm
