Garmin 2720 and 2730 question - BMW Luxury Touring Community
post #1 of 5 Old Oct 12th, 2008, 11:41 am Thread Starter
Reid's Avatar
Hi Guys:
I've got the BMW Navigator that came with my '03 (I think Navigator I) but want to upgrade to 2720 or 2730 (don't need bluetooth ala 2820). I understand the power connectors are different than what I have (presently the round connector is wired in). Is the wiring the same for the new connector? If that's the case I would replace the connector without having to re-run the new power connector.
Thanks for any information.
Reido
K1600GTL...Blue Metallic
USMC 1971-1975
Ham Radio Call: W0FVR
"The right to be heard does not automatically include the right to be taken seriously."
--H.H. Humphrey
Reid is offline
post #2 of 5 Old Oct 12th, 2008, 8:05 pm
Re: Garmin 2720 and 2730 question
I suppose replacing the connector from your current cable wouldn't be that hard. Somewhere, I have the pinouts for the 27xx's power connector. I would question, however, why you feel it's so difficult just to replace the whole power cable and be done with it? Where/How is your current GPS mounted?
post #3 of 5 Old Oct 12th, 2008, 8:20 pm
Mugszy's Avatar
I have the BMW cradle and purchased the 2720 which uses the same "flat" connector for power. The other conector is only for Navigator GPS's that works the left side buttons, these buttons will not work with the 2720 and you will not need them.
Hope this helps...
Mugz
BMWMOA - #45711
2006 K1200LT - Blue Baby
2003 R1150GS - Yellowbird
1981 R100CS - Sadly gone
1986 K100RS - In the past
Mugszy is offline
post #4 of 5 Old Oct 13th, 2008, 9:20 am Thread Starter
Reid's Avatar
Thanks, Joe. Present GPS was dealer installed (it's an LTE and I understand dealers mount the accessories to make it an LTE), so it's mounted on plate and the wires are routed under the tupperware. It looks easier to replace the connector than remove the plastic to get at wherever the connector hooks to the power supply. The pinout diagram would be helpful...maybe I can find it on the Garmin site.
Reido
USMC 1971-1975
--H.H. Humphrey
Reid is offline
post #5 of 5 Old Oct 13th, 2008, 9:22 am Thread Starter
Reid's Avatar
Hope this helps...
Mugz
Thanks, Mugz. My connector is round though. Not sure we're talking the same connector.
Reido
USMC 1971-1975
--H.H. Humphrey
Reid is offline
Garmin 2730 audio connection to Autocom wcarter GPS 5 Jan 8th, 2011 9:12 am
Garmin 2730 GPS Installation mrrick GPS 15 Apr 6th, 2007 9:11 pm
GARMIN 2720 and 2730 Group Buy RVB1019 GPS 9 Jan 27th, 2007 12:14 am
Garmin 2720 questions slugbug GPS 2 May 9th, 2006 10:51 pm
