inch pounds of torque? - BMW Luxury Touring Community
post #1 of 12 Old Oct 11th, 2008, 10:07 am Thread Starter
RocketRon's Avatar
Putting on my new Cee Bailey's windscreen. They want 25 inch pounds of torque and not foot pounds. I don't have a torque wrench that measures in "inch pounds". Can I just "snug" the screws down? How critical is this?
Thanks for your thoughts.
Ron
RocketRon is offline
post #2 of 12 Old Oct 11th, 2008, 10:44 am
Re: inch pounds of torque?
I believe most windscreens crack with the screws are too tight. And, I've yet to see or hear of those screws working themselves out. My rule: Just snug them a little bit and call it "good 'nuff". You could always put a leetle dab of blue Locktite on them to lock them in place, if that would make you feel more comfortable.
post #3 of 12 Old Oct 11th, 2008, 11:14 am
kk610lt's Avatar
put my new cee baileys just before ccr....just snug. had no problems.
kk610lt
2007 K 1200 LT
2004 R 1150 GS Adventure
2002 K 1200 LT (totaled by a SUV 10-7-08)
1988 Concours
Why do bullets bounce off of Superman, but he ducks when you throw a gun at him?
kk610lt is offline
post #4 of 12 Old Oct 11th, 2008, 11:15 am
Enjoy The Ride
saddleman's Avatar
When I removed my BMW windshield 3 of the 4 rubber pads not there and the 3 holes with out the pads where cracked. I installed a #2-4 cee bailey's winshield and used blue locktite using the short end of the hex wrench for the handle. A good inch pound torque wrench that reads that low is not cheap mine only goes down to 100 in #.
saddleman is online now
post #5 of 12 Old Oct 11th, 2008, 11:24 am Thread Starter
RocketRon's Avatar
Thanks for the quick response. My stock screen had NO grommets around the screw and no pad under the "top" thin sheet metal bracket. I used some silicon tubing and cut grommets to go "inside" the windscreen holes around the screw so there was no metal contact.
Riding from Atlanta to Daytona this Wednesday. We'll know by Thurs. if it worked.
Thanks again!
Ron
post #6 of 12 Old Oct 11th, 2008, 11:53 am
rattler50's Avatar
I use a Craftsman torque wrench that starts at 25 in lbs and goes to 240. I use one at work, too. It keeps me from over torquing and twisting the small screws and bolts I deal with. I'm the worlds worst at twisting them off. Plus, in some of the work I do it's very critical. They run around $70 I think...........
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #7 of 12 Old Oct 11th, 2008, 7:22 pm
STARFIGHTER's Avatar
I had heard that locktite could damage a C.B. windscreen......
I use clear fingernail polish
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #8 of 12 Old Oct 12th, 2008, 10:04 am
You are correct. There is a threadlock product that is compatible with plastics. It was discussed in an old thread on this issue. Perhaps someone can find the thread or recall the name of the product.
mjordans2000 is offline
post #9 of 12 Old Oct 12th, 2008, 3:34 pm
Do NOT put normal Loctite on screws that are through plastic. Cracking around the holes will result.
The best way is to get new screws from the dealer. The BMW screws for the windshield have dry thread lock compound already applied to them.
The stock windshield had a flat rubber piece between the windshield and arm, and the screws should only be tightened enough to compress the rubber a little, but not tight enough for the shield to touch the metal of the arms.
post #10 of 12 Old Oct 13th, 2008, 12:39 am
sparky_k1200lt's Avatar
Ron
12 inch-pounds = 1 foot pound. So 25 inch-pounds would be 2 foot-pounds (close enough)
Or do like the rest of us, and snug them until the rubber pads squeeze a bit.
...Bob
1978 GL1000
sparky_k1200lt is offline
post #11 of 12 Old Oct 13th, 2008, 5:32 am Thread Starter
RocketRon's Avatar
I actually took an allen wrench that had a 3" end and a 1" end. I fastened a 25 lb. bag of potatoes on the 1" end and let that tighten it up. Good to go!!!
just kidding
post #12 of 12 Old Oct 13th, 2008, 5:43 pm
scurrie's Avatar
That would work, but why pass up a good excuse to buy a new tool?
-Scott
2005 LT
ARS NS7C
BMWMOA #113753
All Roads Lead To Roads...
scurrie is offline
Swingarm Torque? Sofitel505 K1200LT 5 Sep 13th, 2006 11:42 am
1100 pounds with 700 HP . . .Whoa . . Chick Bike Talk 15 Jul 6th, 2006 5:35 am
Torque Wrench: Need One, Please Advise hschisler K1200LT 23 Jun 16th, 2006 8:51 pm
Fuel Tank Union Nut Torque ? murray K1200LT 23 May 17th, 2006 2:01 pm
