Caliper resetting tool# 34 1 500 - BMW Luxury Touring Community
post #1 of 7 Old Oct 10th, 2008, 9:27 am Thread Starter
Question Caliper resetting tool# 34 1 500
Hi, Has anyone bought or made the BMW No. 34 1 500? If so could you send the dimensions in the forum so I can make this tool? Clymers says to use a piece of 1/8" steel to fabricate but it looks a little flimsy. -K-
hawk20710 is offline
post #2 of 7 Old Oct 10th, 2008, 11:28 am
tbarstow's Avatar
Re: Caliper resetting tool# 34 1 500
That's what large flatblade screwdrivers and scrap wood are for.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #3 of 7 Old Oct 10th, 2008, 12:30 pm
joegottberg's Avatar
Karl,
What-Ya-Trying to do?
I hadn't searched to see where that tool is used, but, when replaced my pads, I used the old ones and a C-Clamp to compress them, no problem.
I'm more of a "rigger" than a special tool buyer
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #4 of 7 Old Oct 10th, 2008, 1:49 pm
if you remove the caliper, you shouldn't have any problem depressing/re-setting the "pistons" using your thumbs actually. It's a little easier if you take one of the old brake pads and a c-clamp, but even that's probably not necessary...save the cash and try it first
trainingwheelz is offline
post #5 of 7 Old Oct 10th, 2008, 4:38 pm
mtrevelino's Avatar
When I first purchased my LT, I bought that tool and the piston spacer. I may have used the tool one time and now just use a screwdriver on the old pads to retract the piston. If I am just flushing the fluid I will use a pair of pliers to push the pistons back in.
The spacer tool would be more helpful to hold one of the front pistons in while you are depressing the other. I am attaching some pictures and some measurements.
Piston Retractor:
1/4" bars
Outside space when open is 1-3/8"
Outside space when closed is 1/2"
Tool is about 2" square where it goes against the pistons
Spacer Tool 34 1 520
3/8" thick
1" wide
2-3/4" long
If you need any additional info, please email me.
ID:	19972   Click image for larger version
ID:	19973   Click image for larger version
ID:	19974   Click image for larger version
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #6 of 7 Old Oct 10th, 2008, 6:19 pm
I just pull the old pads halfway out and "lever" the pistons back. I did make some spacers out of a cutting board to hold them back for my brake flushes.
We don't need no steenking special tools.
post #7 of 7 Old Oct 11th, 2008, 9:55 am Thread Starter
Thanks everbody for the kind help. -K-
Tool usage 101.... bigbear Humor 5 Mar 7th, 2010 5:53 pm
Front brake caliper problem -check all pads Waz K1200LT 0 Jun 10th, 2008 2:24 pm
Caliper bolt snapped!? Ekim K1200LT 15 Apr 18th, 2007 6:22 pm
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 10:48 pm
Tool definitions simoncharles Humor 2 Jun 4th, 2006 7:49 am
