HELP! Won't start - BMW Luxury Touring Community
post #1 of 9 Old Sep 12th, 2008, 10:00 pm Thread Starter
HELP! Won't start
I really can use some expert help here. After work today, I climbed on the KLT but the ignition wouldn't activate. I've put a new battery in the fob and tried to disconnect the negative lead on the battery for 15 minutes or so to reset, but it still won't activate the ignition even though the bikes battery is fully charged. The fob will lock and unlock the bags, but all you hear is a faint noise under the seat when I hit the right button to initiate the start.
She's in a parking lot where helicopters take off and land, so I hate to leave it there very long, and of course all the dealer will say is "bring it in".
Any ideas would really be appreciated! Thanks!!
ELKHNTR is offline
post #2 of 9 Old Sep 12th, 2008, 10:05 pm
Newf's Avatar
Re: HELP! Won't start
The bike is not in reverse is it?
Manny
Where is the nearest Tims?
Need to stay awake
Newf is offline
post #3 of 9 Old Sep 12th, 2008, 11:03 pm
You didn't accidently bump the starter cutout switch to the off position did you?
Did you try starting in neutral and also in gear?
Did you try with the sidestand up?
I never-ever use the key FOB, I have only heard of people having trouble with them. This was a big topic of conversation at CCR with the BMW reps that held an open forum.
As new F stated make sure the bike is fully out of reverse if you used it.
Try doing a search for "won't start" and you may find other suggestions. Let us know what you find out.
Tim Frederick
Woodbury, MN
fredthead is offline
post #4 of 9 Old Sep 12th, 2008, 11:37 pm Thread Starter
That would keep it from starting, but no I've gone through all the silly stuff I can think of that it might be.
I did a search before I asked for help, but it didn't produce anything that I hadn't tried, that's when I came here to the great well of wisdom hoping that someone would know a new trick before I spend the money to have it towed.
I've decided that when I do get her back up, that I'm doing away with using the fob. Being stranded because of that little electronic gagget has always been a worry for me ever since I bought the KLT, so that thing has to go!
ELKHNTR is offline
post #5 of 9 Old Sep 13th, 2008, 9:17 am
joegottberg's Avatar
I've been lucky and not had this (particular) problem.
Generically speaking--I always check to see if the battery is OK. Horn volume usually good enough.
You've checked the obvious stuff when you push the button, no nothing? no click?
I'll bet there is a main fuse that could blow, be careful if your replace it since the short is still there.
Finally, you can always push start it, bet the landing pad is pretty flat. Got any help in the area??
Good Luck
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #6 of 9 Old Sep 13th, 2008, 5:49 pm
olearyg's Avatar
I've had my 2002 K1200 LTC since March with no problems. Then today it won't start. The "R" light is lit, but it's not in reverse. I tried hitting the Reverse lever on and off to take it out of "R", but the bike still thinks it is in reverse, which it is not. Any advice as to how to get the bike to realize that it's not in Reverse?
olearyg is offline
post #7 of 9 Old Sep 13th, 2008, 6:02 pm
grifscoots's Avatar
Sit on the bike and rock it back and forth while moving the reverse knob.
-=grif=-
Grok
grifscoots is offline
post #8 of 9 Old Sep 13th, 2008, 6:30 pm
olearyg's Avatar
I did that, both in reverse and not in reverse, but it still keeps it in reverse, and you can't start the bike in reverse. I don't know how to manual disengage the reverse, or "fool" the bike into thinking that it's not in reverse. Any advice?
olearyg is offline
post #9 of 9 Old Sep 13th, 2008, 8:57 pm
gbob's Avatar
There are 2 micro switches on the rev.shaft /linkage .
I have been told that one makes up the starter relay - neg. lead and the other runs the R light on the panel . I would take the rev knob off and the side cover also and then check out those 2 micro switches
Bob G
gbob is offline
HELP! Alarm went off now bike won't start! blavenia K1200LT 12 Jul 22nd, 2009 11:33 am
Difficult start after refueling Schweintechnik K1200LT 19 Jul 21st, 2009 10:01 pm
2003 LT a No Start Problem knlkern K1200LT 11 Aug 26th, 2008 10:00 pm
Darn thing wont start - any ideas? TWheels K1200LT 17 May 16th, 2007 11:35 am
