Valve Experts - BMW Luxury Touring Community
post #1 of 7 Old Sep 11th, 2008, 11:20 pm Thread Starter
rcalli's Avatar
Valve Experts
I finally checked my valves today, after about 36,000 miles. All were in fine except the # 2 intake. It was a tight 6. I know 6 to 8 is the range, but when do you worry about a tight 6? If it had been a 5, would you change it? Thanks 2005 LT.
rcalli is offline
post #2 of 7 Old Sep 12th, 2008, 4:42 am
grifscoots's Avatar
Re: Valve Experts
If it's a 5, I'd change it.
-=grif=-
Grok
grifscoots is offline
post #3 of 7 Old Sep 12th, 2008, 6:29 am
murray's Avatar
Re: Valve Experts
I would change the bucket at 6. Also you should note all buckets size because next time in there if the valve is tight you will know the replacement size.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #4 of 7 Old Sep 12th, 2008, 9:43 am
Re: Valve Experts
If 5 fits and 6 does not fit just as easily - then change it. Not as critical as an exhaust valve so I might let it go another 12K. But if you spend a lot of time up around 6-7,000 rpm then change it out now.
post #5 of 7 Old Sep 12th, 2008, 9:10 pm
Re: Valve Experts
I have two intakes at .006. Would you change them now?
BEhrler is offline
post #6 of 7 Old Sep 12th, 2008, 9:58 pm
Re: Valve Experts
Anytime you find any valves at the low end, change them to the next size up follower. That will put them at the top of the range. If they are at bottom now, next time they will be too tight. Tight valves are far more of a problem than loose ones. Of course we almost never see loose valve clearance settings on the "Brick" engine, as they normally wear tighter.
If one ever actually GETS looser than the time checked before, you could be on the road to an expensive repair! Valves loosening on any cam over valve style engine is a bad omen. Points to cam lobe wear, or far worse, cam bearing wear.
post #7 of 7 Old Sep 12th, 2008, 10:01 pm
Re: Valve Experts
Perfect. That's what I thought. Just wanted to confirm with someone that knew for sure. Thanks
BEhrler is offline
Simple valve adjustment CharlieVT K1200LT 4 Jun 19th, 2008 9:41 pm
Don't Wiggle the Valve! wardenross K1200LT 11 Sep 5th, 2007 6:11 pm
More Valve Adjustment Questions dglenn1 K1200LT 13 Nov 13th, 2006 4:26 pm
The Scphincter Valve DaFlake Humor 1 Apr 6th, 2006 1:46 pm
