2000 K1200LT Rear Rotor Upgrade - BMW Luxury Touring Community
post #1 of 8 Old Sep 8th, 2008, 4:34 pm Thread Starter
Red face 2000 K1200LT Rear Rotor Upgrade
I want to replace OEM rear rotor for a EBC rear rotor. Does the ABS gear come off so I can put the ABS gear on the EBC rear rotor? I have removed the three (3) screws, but the ABS gear does not come off even with a tap from a rubber hammer? Rotor sounds like a cow bell
thor3101 is offline
post #2 of 8 Old Sep 8th, 2008, 4:41 pm
Re: 2000 K1200LT Rear Rotor Upgrade
Yes, the ABS gear is removed from the old and installed on the new. It takes some persuasion as it is a very tight fit but that is the procedure. Work it carefully until it breaks loose and then reinstall on the EBC rotor.
BuddyP
"The Carolinas"
2003 LTC "Black Beauty"
aka "Tha Motha Ship"
buddyp is offline
post #3 of 8 Old Sep 8th, 2008, 5:00 pm
I just bought a used LT and found out about the rear rotor problems. The new rotors are on back order and I was wondering if you would share the EBC part number for the rotor you are putting on your LT.
klaus110302 is offline
post #4 of 8 Old Sep 8th, 2008, 5:09 pm
Ted
Ted's Avatar
MD615 rear rotor
FA304HH pads
Ted
Camarillo, CA
2012 Ducati Multistrada 1200S - Red
2007 R1200S - Black - Sold
2003 K1200LTC - Silver - Sold
IBA# 16554
Ted is offline
post #5 of 8 Old Sep 8th, 2008, 5:23 pm
Thanks Ted
post #6 of 8 Old Sep 8th, 2008, 5:47 pm
I just called my local EBC dealer and they have to call the distributor to find out the price and availability because they aren't listed on their price sheet. In the meantime, I'm wondering what Thor or others paid for the rotor so I can keep these guys honest.
Thanks for all the help. This forum has been an invaluable resource so far!
post #7 of 8 Old Sep 8th, 2008, 5:51 pm
Ted
Ted's Avatar
http://www.bmwlt.com/forums/showthre...19991#poststop
Ted
Camarillo, CA
IBA# 16554
Ted is offline
post #8 of 8 Old Sep 8th, 2008, 6:09 pm Thread Starter
Smile Re: 2000 K1200LT Rear Rotor Upgrade
I am using EBC rotor and pad combination.
Having problems getting the ABS gear to release for OME rotor. Any ideas other then time lubrication and "tough love"?
thor3101 is offline
What is the gap for the Rear ABS sensor on a 2000 LTC? wildwestrider K1200LT 5 May 2nd, 2008 10:30 pm
Rear Tire for K1200lt with Hannigan Sidecar Hopalong1 Tires 2 Aug 24th, 2006 11:21 pm
