PIAA lights Installed :: Battery Drain? - BMW Luxury Touring Community
post #1 of 6 Old Sep 8th, 2008, 9:32 am Thread Starter
AlReich23's Avatar
I installed the PIAA 1100x light kit this weekend.
I mounted them under the wings.
White wire to the negative battery terminal and Black wire to the positive.
(it didn't work the other way around)
The lights look great, but are they power hungry?
They worked fine while the battery was on the charger.
By the time I got to work (16 miles away) the lights looked dimmer.
I shut down the bike, shut off the lights by the switch.
I attempted to turn them back on, without success.
Any thoughts? Thanks.
- Al
2004 K1200LT [Black]
AlReich23 is offline
post #2 of 6 Old Sep 8th, 2008, 9:49 pm
Re: PIAA lights Installed :: Battery Drain?
- Al
Was this the PowerSports kit, part number 74120? If it was this one, I can go dig out my instructions and take a look as I installed mine a few weeks ago and had no problems with the lights wired as per the directions.
post #3 of 6 Old Sep 8th, 2008, 10:43 pm
dmatson's Avatar
I have 1100's hooked up on my 05' and I have a on board volt meter. When I ride I have them on all the time and never notice a battery drain. Just went out ot the garage and started it up, at idle with the 1100's on it drops from a little over 13v's to about 12.5v's as soon as the R's get to 1500 it is back to normal. Maybe your battery is weak or your alternator is not putting out enough to keep the battery up.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #4 of 6 Old Sep 9th, 2008, 12:57 am
kbikerider's Avatar
I've had the 1100s on my 2000 since CycleGadget offered the kit. They have worked great for the past 7 years. I run them all the time, except when there is oncoming traffic at night.
kbikerider is offline
post #5 of 6 Old Sep 9th, 2008, 2:38 pm Thread Starter
AlReich23's Avatar
Thanks for your help, guys.
I now strongly believe that there is a connection problem in the harness. The lights will kick on and go off by moving the wires around.
post #6 of 6 Old Sep 9th, 2008, 2:52 pm
- Al
Something is wrong here as you have the 12V and ground wire reversed according to the instructions I have for my PowerSports 1100X kit. Black is for ground and white is for +12V.
I assume your kit has the relay and the control switch, correct? Does the LED on your switch light up? What did you connect the switch control wire to? That needs to go to a +12V source also (high beam control if you want to be legal.
With your reversed power connections, I'm wondering if you aren't effectively connecting the positive terminal of your battery to ground through the relay coil. That would explain the draining of the battery. I don't know how the PIAA relay is wired internally, so this is just a guess (somewhat educated as I'm an EE by training).
Matt
PIAA lights vs . . . (product review) Seattle Lighting 7 Jul 11th, 2009 2:13 pm
PIAA 1100X mod - Daytime Running Lights Daza Lighting 7 Jul 10th, 2009 1:11 pm
Flat battery - no lights - no starter Ajlelectronics K1200LT 9 Aug 25th, 2008 2:00 pm
PIAA 1100X Lights coupled with Cruise control ? Orhansky Lighting 3 Jul 23rd, 2007 9:20 pm
Hella FF50 Driving Lights installed unleashd Lighting 22 Aug 21st, 2006 3:11 pm
