signal minder - BMW Luxury Touring Community
post #1 of 5 Old Sep 3rd, 2008, 11:02 am Thread Starter
davek1's Avatar
Question signal minder
Has anyone used the Kissan Signal minder on an LT?
1. Does it work as expected?
2. Is the electronics box easy to get too?
davek1 is offline
post #2 of 5 Old Sep 3rd, 2008, 1:47 pm
Lare's Avatar
Re: signal minder
Why would you need it? Your LT has self-cancelling signals as it is.
Custom sig temporarily unavaiulable while I think about it.
Lare is offline
post #3 of 5 Old Sep 3rd, 2008, 3:51 pm Thread Starter
davek1's Avatar
Re: signal minder
Yes it does.
Mine is an '03 and I am looking to convert the turn signals into running lights as well.
davek1 is offline
post #4 of 5 Old Sep 3rd, 2008, 4:01 pm
STYLNLT's Avatar
Re: signal minder
Regarding the running lights, there are several little kits out there, however what I did is pick up a couple of the same sockets that are used in the taillight housing.
I then, with a dremil tool, routered out the existing turn signal hole to accomidate the larger rubber lamp socket, and so that I could still have the twist-lock function as if it was stock. Took alittle work, but thats what I like to do.
Finally, you can tap into the small running light bulb in the headlight to power the running lamps.
I have photo's of the work at home if you would like me to post them.
STYLNLT is offline
post #5 of 5 Old Sep 3rd, 2008, 5:23 pm Thread Starter
davek1's Avatar
Re: signal minder
If you could post them it would be great.
I have sent you a PM in case there are more pics.
Thanks a lot.
davek1 is offline
