LT gasping air - BMW Luxury Touring Community
post #1 of 14 Old Sep 2nd, 2008, 5:54 pm Thread Starter
Labman's Avatar
Question LT gasping air
My '03 LT has just recently started gasping for air when I refuel?
Is this a sign of something I should be concerned about?
What, if anything, should I do to resolve the issue?
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
post #2 of 14 Old Sep 2nd, 2008, 6:00 pm
Tom1200's Avatar
Re: LT gasping air
Sounds like the carbon canister. Do a search for how to remove it and I think this may solve your issue
Tom Ress
Great White North
Minnesota
Canyon Red 2000
You have to grow up to have a mid-life crisis!!!!!
I could play with women or with cars, I find cars are cheaper and you can write a book about cars a guy would understand.
Tom1200 is offline
post #3 of 14 Old Sep 2nd, 2008, 6:04 pm
SteveHill's Avatar
Re: LT gasping air
Fix it now or you may damage your gas tank.
2000 LTC
Pacific Blue
SteveHill is offline
post #4 of 14 Old Sep 2nd, 2008, 7:50 pm Thread Starter
Labman's Avatar
Re: LT gasping air
OK, will do.
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
post #5 of 14 Old Sep 2nd, 2008, 7:51 pm Thread Starter
Labman's Avatar
Re: LT gasping air
Can you be more specific about damage?
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
post #6 of 14 Old Sep 2nd, 2008, 7:55 pm
Mike_H's Avatar
Re: LT gasping air
Here's a quick way of checking whether the problem is your carbon canister. Locate the small black hose that exits under the saddlebag, probably on the right side.
Remove the gas cap and blow through the hose. Not kidding here. If the air you are blowing comes out of the gas tank filler opening (you'll hear it if it does) you don't have a canister problem.
If you are unable to blow anything through the hose, it's probably plugged. At that point you can either remove the canister as described elsewhere on this forum, or unplug the hose by squirting water through it.
Inside my 60 year old body is a 35 year old brain wondering what the hell happened.
2005 K1200LT
2005 Suzuki Burgman
BMWMOA #130574
Mike_H is offline
post #7 of 14 Old Sep 2nd, 2008, 8:05 pm Thread Starter
Labman's Avatar
Re: LT gasping air
Pardon my ig'nance, but are you refering to the single hose that comes out below the right bag by the back wheel? And are you saying that this is the canister "vent" line?
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
post #8 of 14 Old Sep 2nd, 2008, 8:28 pm
grifscoots's Avatar
Re: LT gasping air
Yes he is. If enough negative pressure builds up in your tank it will collapse, taking the sending unit with it.
-=grif=-
Grok
grifscoots is offline
post #9 of 14 Old Sep 2nd, 2008, 8:49 pm
Mike_H's Avatar
Re: LT gasping air
Labman - exactly correct. The problem that you are experiencing is that the fuel pump is pumping gas out of your tank, but there isn't any make-up air getting into the tank. A low pressure situation is being created. You hear a whoosh of air entering the tank when you remove the gas tank cap. Left uncorrected, the low pressure can create a vacuum which is strong enough to collapse the plastic fuel tank.
Make-up air enters through the hose beneath the right saddlebag, goes through a canister about the size of a mason jar located under the topcase, and then into the fuel tank. The cannister alos collects fumes from the tank and recycles them back.
The canister can become plugged as well, if you overfill the gas tank and fuel runs down the line inot the canister.
As a (cheap) first step, see if the rear hose is plugged.
2005 K1200LT
2005 Suzuki Burgman
BMWMOA #130574
Mike_H is offline
post #10 of 14 Old Sep 2nd, 2008, 9:00 pm
Re: LT gasping air
Is there a filter or anything to prevent dirt, bugs, etc, from entering that hose along with the air?
Voyager is online now
post #11 of 14 Old Sep 2nd, 2008, 11:42 pm
Mike_H's Avatar
Re: LT gasping air
Nope, no filter.
2005 K1200LT
2005 Suzuki Burgman
BMWMOA #130574
Mike_H is offline
post #12 of 14 Old Sep 3rd, 2008, 6:03 pm Thread Starter
Labman's Avatar
Re: LT gasping air
Yo Mike thanks for the extra info. You mentioned "clearing" it out with water. Should I think that this means in the reverse direction? Or by squriting water from the tank back to the canister?
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
post #13 of 14 Old Sep 3rd, 2008, 6:27 pm
Mike_H's Avatar
Re: LT gasping air
Whatever works, just don't get water into the canister. I disconnected the line from the canister, injected water into the line and blew. That worked in my instance because the line was plugged. If your line isn't plugged, the canister is kaput and needs to be removed. Replacement is optional.
You can get to the canister by removing rear seat and the topcase. Both are very easy to do.
2005 K1200LT
2005 Suzuki Burgman
BMWMOA #130574
Mike_H is offline
post #14 of 14 Old Sep 3rd, 2008, 6:53 pm Thread Starter
Labman's Avatar
Re: LT gasping air
Ok that's what I thought. I appreciate the extra info again.
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
