steering dampener - BMW Luxury Touring Community
post #1 of 13 Old Sep 1st, 2008, 8:14 pm Thread Starter
rcalli's Avatar
steering dampener
Is there an adjustment that can be made to the dampener? The thing looks like there is as there is a slot in the end of the rod coming out of the front of the unit. I thought it might help control the "headshake".
rcalli is offline
post #2 of 13 Old Sep 1st, 2008, 8:24 pm
wacolt's Avatar
Re: steering dampener
I don't know about the adjustment, but the headshake may be due to cupping of the front tire. Damping of the headshake may also indicate a failed damper.
Find it on-line; normal cost new is $300.00 plus. Used are about 50% of that.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
post #3 of 13 Old Sep 1st, 2008, 9:23 pm
Cat Herder
andy's Avatar
The stock steering dampener is not adjustable. Only aftermarket ones are. That said, after I had my aftermarket steering dampener installed on my LT I never changed it, so the adjustment is kind of a moot point.
andy is offline
post #4 of 13 Old Sep 2nd, 2008, 3:00 am
leiboshi's Avatar
Stock model is not adjustable, as written above. The slot in it is only for assembly. When installing seals into damper which is full of oil, it creates over pressure and this is coming out through rod hole. When damper is completed, that hole will be closed by seal and slot screw.
Regards
Leiboshi
leiboshi is offline
post #5 of 13 Old Sep 2nd, 2008, 4:35 am
STYLNLT's Avatar
What would then be an indication of a dampner that needs replacing. (other age or milage)?
STYLNLT is offline
post #6 of 13 Old Sep 2nd, 2008, 6:43 am
wacolt's Avatar
Oil residue on the damper and headshake in a curve during acceleration was my experience. The headshake was enough to flare my nostrils; didn't stiffen my arms, sloooooowly rolled off the throttle, didn't accelerate in curves, as I had done, until the damper was changed.
Rider of Stahlross
1999 Basalt Grey LT
wacolt is offline
post #7 of 13 Old Sep 2nd, 2008, 7:16 am
ArthurCal's Avatar
It's also worth getting the wheel balancing checked. I was getting headshake which I initially though was steering damper but the garage balanced the front wheel and it went away. It wasn't a heavy wobble when upright but became disconcerting on corners at 'high' speed.
ArthurCal is offline
post #8 of 13 Old Sep 2nd, 2008, 9:04 am
Cat Herder
andy's Avatar
Put your bike on the center stand, have your wife sit on the REAR seat so that the front wheel is in the air. Then move the handlebars quickly from one side to the other. You will either feel the steering dampener, or not. It is quite pronounced. When mine was up for replacement it took almost 5 inches of movement before it kicked it. As I said, it is quite pronounced.
andy is offline
post #9 of 13 Old Sep 3rd, 2008, 1:49 am
STYLNLT's Avatar
Thanks. When I was coming through Herber last week during the wee hours of the morning, streets quite, and my hands were light on the bars, at about 30mph or so, I noticed the front would begin to wobble.
I tried what your describing the week before 08CCR, and mines at around 3 inches before I begin to get that pronounced buffed stop. No leaks, just the distance.
I'm coming close to replacing the front tire, so I'll wait to do that knowing all will be balanced, etc. then if I continue to experience the problem, then I'll lean towards replacement of the dampner.
STYLNLT is offline
post #10 of 13 Old Sep 4th, 2008, 12:32 pm
Waz
Hi,
My 2005 LT has never suffered from tank slappers until a recent trip loaded up with luggage, which incidentally caused the bike to just sit down on the back wheel when on the centrestand.
The wobble wasn;t too bad and only at around 30mph and not under acceleration.
If your problem occurs during normal loading, other replies have prob ably covered the issue.
Waz
Waz is offline
post #11 of 13 Old Sep 4th, 2008, 1:13 pm
I searched for the post on the steering dampener re-build some time back but I could not locate it. Does anyone have the link to that post? Has anyone actually tried it and had it work?
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #12 of 13 Old Sep 4th, 2008, 2:48 pm
Slade2's Avatar
hi
I have resealed my dampner and went with a little heaver oil(never did find spec for oil weight) . It works better than ever now.
I got the seals from my local NAPA DEALER the freight was more than the seals but BMW told me the dont sell seals sepratley. Sorry dont remember number.If needed i can find it.
Slade2 is offline
post #13 of 13 Old Sep 4th, 2008, 3:34 pm
leiboshi's Avatar
Hi!
I have done it twice, for two different LT's. 2000 and 2004 models.
Both purchased used. First one had oil leakage second one had some free gap, as Andy described it.
Both cases I removed dampener from bike. This requires front wheel removal and front fender removal.
I opened a small all slot screw in dampener rod, took eye screw away from from rod, took circlips off from damper body ends and pushed entire rod with piston out from dampener. This push seal out. This has to be done to both directions while there are similar seals on both ends.
Then I took that seal with me and I went to hydraulic spare part shop and purchased two new seals according to sample. Price was 1,5 Euro (about 2 USD) each.
Next phase is to clean all parts well.
Assembly. Take seal and put some oil into it's outer surface and into it's hole. Oil should be same as you are going to use in dampener. I am not hundred percent sure what oil is best/correct, but I have used automatic gearbox oil. Front fork oil should be ok as well, I think. In any case both oil types are used in hydraulic's.
Push now one seal into its place, install circlip. Keep dampener so, that it is open end upwards. Pour some oil into dampener. Put piston rod into it (blind end first) and push it to the end, against seal. Now pour oil inside so that it is full of oil. Put seal into its seat and push it inside to end of it's seat. A small seal part inside rod is coming out with some oil. Install circlip to secure end seal. Now pull rod out, fill rod hole with oil, if it is not full. Push it down and pull it up couple of times to see if air bubbles ore coming out from dampener. Make sure that rod hole is full of oil whole time when you do this to avoid any air to go into dampener. Put small seal part into rod hole back and install that slot screw into it. Tighten it well (no torque info available). Install eye screw to the end (correct one, as it was in the beginning). Now it it is ready to be assembled back into your bike.
You have to clean both, dampener thread and dampener bolt well with solvent and then use thread locking glue to lock fixing screw when installing dampener into the bike. Install fender and wheel.
So, this was how I have done it.
Whole work takes maybe 2 hours altogether. And total costs are two seals and oil. Few bucks. But your dealer won't tell that to you. He will sell you new dampener with several hundred bucks and installation work additionally! Attn! Seals are not awailable by BMW, only complete damper.
So, it is not big job, if you know what to do and how to do it. And if you are interested to do it.
I know that many of you are afraid of this job because of insurance or warranty issues. Well, then it is better to let your dealer to do it.
What is interesting is that these seals used by BMW are seals for rotating shafts, not for shafts making stroke thus this rod is only for stroke movement, thus quite slow one. Maybe it is used because of seal lip. I think that it is keeping shaft cleaner and I think it keeps dirt better out from dampener.
Sorry, I do not have any pictures done of that work. That is why I tried to desribe as well as I could.
Regards
Leiboshi
leiboshi is offline
HyperPro Steering Damper oknplm K1200LT 11 May 17th, 2008 3:59 am
steering dampener disassembly beemerfan K1200LT 1 Jan 30th, 2008 9:50 pm
Steering Dampener Problems? chrisorkelly K1200LT 8 Aug 16th, 2007 12:38 am
steering dampener kip Shocks and Suspension 31 May 9th, 2006 8:33 am
Steering Dampener Leaking robasay K1200LT 6 May 8th, 2006 6:48 pm
