Service Trans with hydraulic center stand???? - BMW Luxury Touring Community
post #1 of 10 Old Sep 1st, 2008, 5:13 pm Thread Starter
Chipper's Avatar
I will be doing a 12K mile service for a friend of mine who has an LT with the hydraulic center stand. My question is does it need to be removed to access the trans drain plug or is it a partial removal????
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
2004 RTP Work Bike(Retired)
2002 LTE Totaled Aug/2011)
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #2 of 10 Old Sep 1st, 2008, 5:26 pm
Re: Service Trans with hydraulic center stand????
None of the above. There are step by step instructions in the hall of fame, just do a search for 'transmission drain" or start here:
http://www.bmwlt.com/forums/showthre...smission+drain
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #3 of 10 Old Sep 1st, 2008, 10:48 pm Thread Starter
Chipper's Avatar
Thanks, for the info, I have done my own transmission service on my 02 but I just wanting to know if I was going to have any surprises with his newer bike...
So I guess its safe to say based on your "none of the above" the center stand motor is not in the way of the drain plug...
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #4 of 10 Old Sep 1st, 2008, 11:36 pm
powwow's Avatar
Just changed the transmission fluid on my '07 LT with the power center stand this weekend. Put it up on the center stand, but also put the side stand down to allow access on the left side.
Life happens...you control your reaction.
2017 KTM 350 EXC-F (single track monster)
2018 Honda CRF250L Rally (fun on the fire roads)
2015 R1200 RT (holy cow…what a bike)
2007 K1200 LT (sold)
2005 DR 650 (sold)
2002 Harley Ultra (sold)
1999 Harley Road King (sold)
1996 K1100 LT (sold)
1990 Honda Shadow (sold)
1978-1993 Raising Kids; Paying Mortgages
1975 Honda CB550 (sold but wish I still had)
Homemade Motor Bike (mounted a 3.5 HP Briggs & Stratton on my bicycle at age 12)
powwow is offline
post #5 of 10 Old Sep 2nd, 2008, 12:05 am Thread Starter
Chipper's Avatar
Thanks Larry for the information..
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #6 of 10 Old Sep 2nd, 2008, 1:28 pm
bjedruszczak's Avatar
There may be waiting a surprise for you if you don't have a special or modified hex wrench (L-shape). Standard length will not fit, so you will have to saw it off to fit, unless you can get ahold of a short ended one.
BJ
2015 R Nine T
2007 LT Storm Grey
2005 LT Gold (traded in for '07)
2007 G 650 Xchallenge
bjedruszczak is offline
post #7 of 10 Old Sep 2nd, 2008, 1:32 pm
Exclamation Re: Service Trans with hydraulic center stand????
Transmission oil should be changed every 24000 miles (40000km), so if it is a 12k miles service you don't have to do this, unless you have problems with gears shifting.
BJ
2015 R Nine T
2007 LT Storm Grey
post #8 of 10 Old Sep 7th, 2008, 9:05 pm
I just did mine. at 12900 . I used synthetic and it made it shift much smoother.
Yes, the drain plug is a problem child. But you do have to loosen the hanger for the exhaust and then move things out of the way. I made a drain troft out of cardboard, and it worked great. The trick is to get the fluid back in .
I filled it till it ran out of the hole, then stopped.
Its the only way I could figure out.
2002 LTC.
sailheli is offline
post #9 of 10 Old Sep 7th, 2008, 10:28 pm
2002 LTC.
For filling the tranny with gear lube, I use a baby bottle with the very tip of the nipple cut off. I write on the bottle with a magic marker as to how many ounces it takes; the type of lube; and the size of the crush washer for the fill plug, as well as the torque setting. I measure out a total of 21 ounces (7 ounces in a bottle 3 times = .67 qt per the book). Close enough for me. HTH.
post #10 of 10 Old Sep 7th, 2008, 11:05 pm
Now, if we can just remember where we put the bottle..?
Remember to wash out the pablum before using on your baby.
J.M.J...
Dcn Channing
Hydraulic Center Stand Rebuild and Flush Procedure joegottberg K1200LT 5 Apr 19th, 2010 9:42 pm
Hydraulic Center Stand Retrofit nbbusa K1200LT 12 Oct 12th, 2009 11:08 am
Side & Center Stand Questions tonygret K1200LT 6 Jul 12th, 2008 6:32 pm
Center Stand Lubrication for Pre 2005 MattKas K1200LT 9 Oct 19th, 2006 1:16 pm
Center stand difficulty Schweintechnik K1200LT 19 Oct 19th, 2006 8:55 am
