Brake pads...oil leak - BMW Luxury Touring Community
post #1 of 3 Old Aug 30th, 2008, 11:44 am Thread Starter
itspossible's Avatar
Last night I changed out the rear brake pads, the old ones were thinner than I realized when I removed them. Had to push the caliper pistons back in a couple of times to slide the new ones in. Everything went well, did a test drive and all was good.
This morning I woke up to a 2 inch diameter puddle of very thin oil under the bike. Nothing seems to be leaking but I do see a rubber line coming off the bottom of the right rear reservoir and heading to the front of the bike that was wet with oil.
I'm thinking I forced oil out of the system when I pushed the caliper pistons open but would like to know where it would vent from if this is the case. The brake oil I'm using is clear so I can't tell where the level is in the rear right reservoir.
Any thoughts?
thanks
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
itspossible is offline
post #2 of 3 Old Aug 30th, 2008, 11:53 am
Re: Brake pads...oil leak
The same thing routinely happens to me. The rear reservoir has to be almost completely full on my '03LT in order to stop the flashing brake warning lights. When you pushed the calipers back in, you displaced some of the brake fluid. I see the fluid under the front of the right side case-the reservoir is just behind the front of the case. Not to worry.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 3 Old Aug 30th, 2008, 4:19 pm Thread Starter
thanks Alan, just back from a long ride and all seems well, no leaking, brakes are fine.
Ron
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
An Oil Man's View robasay Chit Chat 38 Jun 25th, 2009 8:28 am
$65 oil is coming (maybe) RTTommy Chit Chat 17 Oct 10th, 2008 9:43 am
OEM rear brake pads CharlieVT K1200LT 1 Jul 13th, 2007 11:14 am
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
