Leaky rear wheel? - BMW Luxury Touring Community
post #1 of 5 Old Aug 30th, 2008, 10:31 am Thread Starter
Leaky rear wheel?
The rear tire on my 2007 LT has lost air pretty much since new. It was only a couple of pounds a week at first and increased to about 4 psi per week as the tire neared replacement condition. I figured it was the tire or valve stem so I thought the new tire and stem would cure the problem. No such luck. I just checked the new tire after about a week and it has dropped from 48 to 44. My front tire holds air just fine. It will be down 1 psi in a month.
Has anyone else had this problem? I'm suspecting now a porous wheel, as I know this sometimes happens with cast alloy wheels.
post #2 of 5 Old Aug 30th, 2008, 11:22 am
dukey33's Avatar
Re: Leaky rear wheel?
Mine only loses that much over ~4 weeks so you are correct that something is awry.
Check the valve stem core to make sure it's tight. I've had new stems with the core loose. A good cap is also important since the centrifugal force tries to pull the stem open (hopefully you don't have one of those goofy red/green pressure monitor caps. They're all-around bad news).
If your bike weren't so new I might suggest there could some rubber and tire lube build up in the bead area of the wheel. This should be cleaned with a scotchbrite pad whenever the tire is replaced to ensure a good seal. But unless you've already gone thru several tires on your 07, this is unlikely to be be the culprit.
If you have a big enough tub, maybe remove the wheel and submerge it in water. Look for bubbles. But at such a small leak rate, you may not be able to see any.
Finally, maybe a product like Ride-On would slow the air loss (and balance the tire too!).
-2000 K1200LT
dukey33 is offline
post #3 of 5 Old Aug 30th, 2008, 9:14 pm
The two main sources of air leaks are an improperly cleaned bead area during the tire change and the rubber valve stem. I scrub my bead area and have gone to metal valve staems and no leaks on five sets of tires.
post #4 of 5 Old Aug 31st, 2008, 3:23 pm
I properly cleaned my rims, mounted tires properly and yes, they just lose air.
I put "Ride-on" in the front tire and it slowed... a lot.. But then I had to replace the tire...
Still losing it.,... ca'use I don't have any more Ride-on..
J.M.J...
Dcn Channing
post #5 of 5 Old Aug 31st, 2008, 7:33 pm Thread Starter
At what rate do your tires lose air? My front has negligible loss, but the rear is ~4 psi per week which is annoying.
Rear Wheel Drive Good Arthur K1200LT 7 Nov 1st, 2013 12:44 pm
Checking rear wheel bearing play Oisin K1200LT 3 May 26th, 2008 3:08 pm
Loose Rear Wheel thalpin K1200LT 15 Apr 13th, 2006 2:47 pm
