LT front wheel removal (Am I an idiot?) - BMW Luxury Touring Community
post #1 of 11 Old Aug 29th, 2008, 11:14 am Thread Starter
djfalkenstein's Avatar
So I removed the front wheel to have new rubber installed. The procedure is strait forward enough with one exception; the brake rotors. After loosening the calipers I could not see a way to easily slip them over the rotors without using a heavy hand or disconnecting the brake lines. On my '07, the brake calipers seem to extend almost to the wheel itself on both sides. I removed the rotors and ABS ring (making a mental note of the shimmed legs).
Nowhere else do I see any mention of this extra step. Am I being too conservative (or an idiot) for removing the rotors as well to get the wheel off?
DJF
djfalkenstein is offline
post #2 of 11 Old Aug 29th, 2008, 11:20 am
zippy_gg's Avatar
Re: LT front wheel removal (Am I an idiot?)
No need to remove rotors and ABS ring.
Just before removing the calipers you need to wiggle them gently side to side to push the pistons back in as you will need that little extra room to tilt the calipers sideways in order to clear the wheel. Some use masking tape on the wheel so the calipers don't scratch it; not a bad idea.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is online now
post #3 of 11 Old Aug 29th, 2008, 11:23 am
All you have to do is remove the brake pads from caliper. This gives you enough side way movement to remove calipers. You can also use painters tape to cover/protect inside rim and eliminate scuff marks during removal process. I have never had to remove the other items you did.
May we never find the end of the road!
oknplm
oknplm is offline
post #4 of 11 Old Aug 29th, 2008, 11:25 am Thread Starter
Oops. Perhaps my ex-wife was right..... Thanks.
DJF
post #5 of 11 Old Aug 29th, 2008, 11:30 am
zippy_gg's Avatar
Talking Re: LT front wheel removal (Am I an idiot?)
Naw! Ex-wives are NEVER right!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
post #6 of 11 Old Aug 29th, 2008, 2:50 pm
BecketMa's Avatar
Someone suggested getting one of those cheap small C-clamps at a hardware store, one with plastic covering the tips of both legs. I use that to push the brake pads against the brake.
Bob. 00LT
BecketMa is offline
post #7 of 11 Old Aug 29th, 2008, 3:02 pm
leiboshi's Avatar
oknplm
I have never removed brake pads when removing wheel. Just push pads gently in (so that piston goes inside) by using some suitable tool e.g. big screwdriver and you can remove caliber with pad without any further problems.
Regards
Leiboshi
leiboshi is offline
post #8 of 11 Old Aug 29th, 2008, 4:08 pm
I alway took pads out. It is easy to do, provides amble removal space and you are able to visually inspect the pads for wear and/or heat glazing. I also had the habit of swapping the pads around because there always seemed to be one side of the pads that wear out more quickly. Kind of like: If you are in the same area working, why not take a few extra steps for inspection and prevention of vital component.
oknplm
Regards
Leiboshi
oknplm is offline
post #9 of 11 Old Aug 29th, 2008, 10:56 pm
dmatson's Avatar
Once you do have the rotors off, (how ever you do it) do your self a favor by putting a tennis ball or something like it between the grip and the brake handle also protect the rear brake pedal with something. You don't want someone to walk into your garage and activate your brakes.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #10 of 11 Old Aug 30th, 2008, 8:35 am
ChasnRacin's Avatar
x2!
2006 Magnesium Black Metallic K1200LT
Proud Member of the Patriot Guard Riders
ChasnRacin is offline
post #11 of 11 Old Aug 31st, 2008, 1:32 pm
secretaryrick's Avatar
One step no one posted yet was to mark with a piece of tape the spot on the rim of the wheel where you took the calipers off, so when re-installing them you know where they had room to be removed, and therefore installed again. I know the rim should be round, but this little extra step really helped me put it all back together again.
Good luck.
_________________________
2000 K1200 LT
1973 R75/5
1999 Honda Africa Twin (sold)
1999 R1100 RTP (sold)
1998 R1100 GS (totaled)
1991 R100 RT (sold)
1988 Honda NR250 (sold)
1983 Honda CB350 (sold)
secretaryrick is offline
k1200lt front wheel clayton K1200LT 5 Jun 20th, 2008 10:47 am
Bent Front Wheel HornHonker K1200LT 3 Mar 16th, 2008 9:49 pm
front wheel removal HowardRichman K1200/1300GT (The Next Generation) 6 Sep 1st, 2007 10:45 pm
Front tire removal Q Rondeau K1200LT 11 Oct 7th, 2005 11:22 am
