Final drive oil temp gauge - BMW Luxury Touring Community
post #1 of 12 Old Aug 26th, 2008, 4:28 pm Thread Starter
pozo_izquierdo's Avatar
Here is a picture gallery of my final drive oil temperature monitoring system.
http://picasaweb.google.com/pozoizqu...VEOILTEMPGAUGE
At first I was using a regular VDO oil temperature gauge with a range of 50 - 150 deg C ( 122 - 300 deg F) but it was wrong range ( too high). The new gauge is actually labelled for hydraulic oil temp metering ( 20 - 100 C / 68 - 212 F) and with the properly calibratated VDO sensor I now get a quite accurate reading of my rear drive oil temperature.
I want to emphasize that I am not paranoid about my final drive. I have had no failures so far but I had the main bearing changed at 63.000 km last year together with my (self broken) gear box. I just happened to have locations for three extra gauges and oil temperature gauges (both engine and final drive) are quite easy to install. So now I can watch my engine oil temp go quite fast up to 73 deg C ( 163 F) while the final drive oil takes much longer to climb up to 53 deg C ( 127 F). This takes about 40 minutes on an autobahn at 140 km/h. And on rainy weather the temperature goes down dramatically ( 15 - 20 deg C) because of the cooling effect of the evaporating water on the drive housing.
So if my final drive temperature ever starts to raise to 60 deg C ( 140 F) and above I might start wondering what is going on...
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #2 of 12 Old Aug 26th, 2008, 8:10 pm
mongo's Avatar
Re: Final drive oil temp gauge
Nicely done. I have a new direction in life- I will strive to place at least 10%
of your farkles on my LT.
Scott
Shingle Springs + Redwood City Ca
2008 K1200LT Black, (Big Black Whale)
2008 DRZ400SM white (Thumpers) wife's
1975 GL1000, Red #18406 (Lazarus)
1994 Quarter Horse, Brown, #3292487(Gaucho)
mongo is offline
post #3 of 12 Old Aug 26th, 2008, 10:21 pm
Motomadman's Avatar
Ari any VDO part numbers that you can post so we can avoid the confussion you incountered? Another great Idea......
Craig Hutchison
02 Pac Blue (Aka Blue Ox)
34° 14’ 12.63 N
119° 01’ 21.64 W
Why coast through Life when you can Corner it.
Motomadman is offline
post #4 of 12 Old Aug 26th, 2008, 10:31 pm
Ari... my wife just asked.. "How much MORE does that bike weigh with all that k..., "stuff" on it???"
Yeah, I know, she doesn't understand.... but that's part of what I love about her... and she just smiles that I like this stuff too.
J.M.J...
Dcn Channing
post #5 of 12 Old Aug 27th, 2008, 1:35 am
motorhead's Avatar
Great idea .... But bummer for our LT .... out of room for instruments, farkle overload at present.
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #6 of 12 Old Aug 27th, 2008, 2:38 am Thread Starter
Thanks to all for your interest.
Craig, sorry I don't have the VDO part numbers available but the critical dimensions of the correct sensor are: Thread: 14 mm, length of the sensor with thread included: 15 mm. The sensor has a code "907" stamped on it but I don't think it is the part number. The "wrong" sensor that I had originally was 40 mm long and that was way too long.
And as I said, the optimal gauge has the range from 20 - 100 C or 60 - 212 F.
Channing, you can tell your wife that my bike weighs about 20 kg more than stock with all the kitch eh...farkles. This was proved when both mine and my CCR buddy Jouko's bikes were weighed just before the air freight from Toronto to Frankfurt two years ago. Mine was 445 kg and Jouko's bike was 424 kg. Of course we both had the cases full of riding gear and other stuff that we did not carry with us on the flight.
Best regards
Hyvinkää, Finland
post #7 of 12 Old May 4th, 2015, 9:12 am
mats.lundmark@live.se's Avatar
Originally Posted by pozo_izquierdo View Post
....Craig, sorry I don't have the VDO part numbers available but .......
Hi, (very old thread but...) as I am going to mount a temperature gauge and sensor for the finaldrive I have found these part numbers from VDO to suit this purpose:
Temperature gauge International 20-100 °C
Part.nr.:310 030 022
Temperature sensor 120°C M14x1,5
Part.nr.:323 801 001 006
If you need the gauge reading °F I am sure you will find it by searching the above part.nr.
@pozo_izquierdo do you have any more experiences about "normal condition temperature readings" of the FD? Any other good info about this "farkle"?
ID:	79433   Click image for larger version
Mats
2011 K1600GTL Mineral Silver Metallic ~50,000 miles
Navigator V, Schubert S.R.C.
Sold: 2005 K1200LT Ocean Blue ~43,000 miles
Navigator III+, Cardo Scala Rider G9x
___________________________________
post #8 of 12 Old May 4th, 2015, 9:50 am Thread Starter
Hej Mats,
just making sure the picture you posted of the sensor is way too long but I guess that is just showing a general picture of the sensor principle, right?
I have run the bike with Red Line Heavy gear oil in the FD and it seems to run slightly cooler than with the regular gear oil. I run it with Red Line through two oil changes (2 x 10000 km) and the third leg I use regular 80-90 W "BMW approved" gear oil.
I have a spare FD in the garage and change the whole unit every 60.000 km without any further inspections or analysis. Then during the winter I pull the main bearing out, check the shimming and leave it wait on my shelf.
BTW, why don't you take your time and visit our 9th annual BMWKLTIBMIKOF-meeting and take some of friends along!
https://sites.google.com/a/bmwkltibmixof.com/english/
We have had many nationalities (Swiss, Austrian, Italian, German, Norwegian, Lithuanian, Australian, Belgian, Latvian, American, British etc.) visiting us over the years but so far no Swedes!
There you would see some "farkelized" LT:s, GTL:s etc. We still have no mandatory inspection (TÜV or similar) like many countries have...;-)
Vi även talar svenska!
Best regards
Hyvinkää, Finland
post #9 of 12 Old May 5th, 2015, 5:44 am
norton's Avatar
Ari, your are the hands down the true farkle king and I bow down before you.
Scott
2007 LT
norton is offline
post #10 of 12 Old May 5th, 2015, 10:44 am
+1.
Many of us Finns try to copy (some part) of Ari's inventions...
Born to be wild so why not
C-A-D is offline
post #11 of 12 Old May 6th, 2015, 7:25 am
Thumbs up Re: Final drive oil temp gauge
.....I guess that is just showing a general picture of the sensor principle, right?......
Hi Ari,
Yes you are right about the picture. The product.no. given here have a length of 15mm just as you mention in the thread.
Regarding the BMWKLTIBMIKOF-meeting; Seppo already invited me
By the dates for the meeting me and my wife will be riding the bike in Croatia. Hopefully next year? ThanX anyway for your invitation.
Regards,
Mats
post #12 of 12 Old May 7th, 2015, 3:04 am
Cool Re: Final drive oil temp gauge
..just making sure the picture you posted of the sensor is way too long........
I checked this again and unfortunately I gave the wrong article#. The correct number is 323-801-012-002
Attached you will find the catalogue (page 31) where I found it.
Sorry for any inconvenience.
Mats
An Oil Man's View robasay Chit Chat 38 Jun 25th, 2009 8:28 am
Discussed alot, Final drive oil. cali_beemer K1200LT 6 May 14th, 2008 8:52 pm
Gear / Final Drive oil same ? simoncharles K1200LT 4 Apr 7th, 2008 3:01 am
Thinking of getting a spare Final Drive after seeing muddy oil at oil change MattKas K1200LT 3 Feb 11th, 2008 4:51 pm
