k1200lt windshield retractor arms - BMW Luxury Touring Community
post #1 of 16 Old Aug 25th, 2008, 8:40 pm Thread Starter
Hello, just joined this community as I have recently purchased a 2002 K1200LT and have a question already. The windshield retractor arm pin and spring have popped out of the arm itself and I want to replace them. I have the windshield removed and am trying to remove the plastic panel directly behind the windshield which will provide access to the arm, but it appears to be stuck. I have removed all the screws that I can see and the panel is loose, but something is holding it in the centre section, very close to the dome light. Has anyone had experience with this item that could share some knowledge as to what to do next. It looks as if just some additional force may be the answer, but unsure at this point and don't want to break it and make this a worse situation
Thanks in advance
45cycle is offline
post #2 of 16 Old Aug 25th, 2008, 9:06 pm
Re: k1200lt windshield retractor arms
Thanks in advance
There is a screw behind the "dome" light. You need to carefully insert a screwdriver in the notch at the left side of the light and pry it out. The screw is hard to see, a flashlight helps.
If you don't have the BMW service CD or a Clymer manual, I strongly suggest getting one or both.
post #3 of 16 Old Aug 26th, 2008, 12:11 am
The screw behind the dash light should do it, If not, you missed the two screws in the slots that the arms come through. Once you get the cover off be prepared to repair it yourself. The arms are not a part you can order, You must buy the whole assy with the motor and all. And that is very expensive.
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
post #4 of 16 Old Aug 26th, 2008, 8:42 am
jers99lt's Avatar
Here's some repair info I received after I made what I thought was a fairly clean fix: http://www.bmwlt.com/forums/showthread.php?t=33784
HTH,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #5 of 16 Old Aug 26th, 2008, 11:02 am Thread Starter
Thanks for the insight, job done! The pivot pin anchoring the spring and the retractor arms is now in proper place in the plastic housing working as intended.
45cycle is offline
post #6 of 16 Old Sep 11th, 2008, 6:48 pm
I just broke the bracket behind the dome light getting to the windshield bracket. I can fix it but their needs to be more info on the best way to access the parts of the BMW LT. I want the simpliest and most direct route to service the bike. That windhshield assembly is way to fragile for my engineering taste.
ironhorsenc is offline
post #7 of 16 Old Sep 12th, 2008, 11:12 am
Steve_R's Avatar
While that windshield assembly seems might fragile, the breakaway capability of it will keep you from getting seriously hurt by a more rigid set up. But I have to agree that should be several replaceable pieces instead of one very expensive part.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #8 of 16 Old Aug 18th, 2009, 5:21 pm
CVV
CVV's Avatar
Hi everyone,
I guess I'm not the only one that's having problems with my windshield. I was wondering if I could get some 'guiding light' (input) to the problem I'm having with mine. Here goes nothing:
I'm having problems in getting the windscreen to raise up all the way. There is no binding (as far as I can tell) and I've also lubed the pivot arms to give it some freedom to 'slide back and forth.' I've been told that it may be the motor that has a dead spot in it at that specific place. I'm just wondering if it may be something else that could be binding? Any suggestions would be appreciated.
Thanks for your help,
CVV
CVV is offline
post #9 of 16 Old Aug 18th, 2009, 7:56 pm
mrbiker's Avatar
Originally Posted by CVV
Hi everyone,
CVV
Is it while riding on the freeway (I'm now a true Californian - I say freeway. It was expressway where I grew up, Massachussetts)? If so, it's normal. Some bikes have no trouble with freeway speeds (like mine) but some do.
If I remember correctly (from reading posts) there's nothing you can do about it short of replacing the motor. You may have to live with slowing down to the speed it goes all the way up and then speeding back up again. Or you can buy a newer one (2005 and up) on fleabay, they're now going for a reasonable amount.
My $0.02. YMMV.
Chime in hear if I'm wrong, peoples.
mike p
2005 BMW K1200LT (got it in July 2007)
2002 Kawasaki Ninja ZX-12R (parked next to the LT)
1982 Suzuki GS-750EZ (paid $500
for it in 1985, sold it for $450 in 2000)
1978 Honda CB-500F (sold in 1980)
1976 Honda CB-400F (drowned to
death in the blizzard of 1978 in Boston)
mrbiker is offline
post #10 of 16 Old Aug 18th, 2009, 8:03 pm
CVV
CVV's Avatar
Thanks for the quick reply. I was even testing it out with the machine standing still. Goes up most of the way and then just sits there. I know I was using it 2 weeks back on my vacation and it worked fine. I guess when she goes...she goes.
Yup...I suppose I'll check what Fleabay has to offer.
Thanks again for your help,
Cheers.
CVV
CVV is offline
post #11 of 16 Old Aug 19th, 2009, 7:40 am
If you need a new motor, I have one . I already cannibalized the arms, but the motor is virtually new.
jrlakin is offline
post #12 of 16 Old Aug 19th, 2009, 12:22 pm
SilverBuffalo's Avatar
Motors are very available, because they rarely fail
most of the problems with raising and lowering the windshields can be solved with just a little lubrication,
really it's just that simple!
so before you start replacing parts,
if your windshields moves a little,..... lube it (some more)
if it doesn't move one direction or another check both relays,
if it doesn't move at all, then check the motor.
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #13 of 16 Old Aug 20th, 2009, 2:14 pm
CVV
CVV's Avatar
Hi Everyone,
Thanks for all the input! Greatly appreciate it. Have lubed the pivot arms before but the only issue is that it goes up 3/4 of the way and stops. Tried to repeat this several times to see if I could 'jarr' it any further...but I believe there may be a dead spot in the motor. Yup, motors don't fail too often, but if anyone has more suggestions, it'll be great. If it is the motor, any great steps I need to know before I dig this thing out? Can it be done without removing all that tupperware? I can see a clear shot of it around the headlight, but if things will start falling out of it when I remove the motor, then I will have to take the plunge and of course do it the long way.
Once again, thanks for everyones help!
Cheers,
CVV
CVV is offline
post #14 of 16 Old Aug 21st, 2009, 6:14 pm
That tells me the problem is not the motor,
by the time the windshield gets 3/4 up the motor has made many revolutions,
I'm going to guess that one of the pivots is broken at the bracket,
you'll need to remove the windshield and the cover behind it,
six screws plus one behind the map light and you've got access.
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #15 of 16 Old Aug 21st, 2009, 10:31 pm
CVV
CVV's Avatar
Thanks for the guided support. I will check that out tomorrow.
Take care everyone!
Regards,
CVV
CVV is offline
post #16 of 16 Old Aug 22nd, 2009, 4:11 pm
casualemt's Avatar
Hi, Recently had to repair the windshield bracket for my 2000 LT, I downloaded a repair manual for free from http://pdftown.com/BMW-K1200LT-Service-Manual.html it told me about the screw that hides behind the light fixture. I cannot say that the manual is an "idiots guide" but it is a great resource, and I have been able to do a few other maintenance jobs on the bike easily because of it.
Enjoy your new bike
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
K1200LT Windshield vibration bvick K1200LT 9 Jan 11th, 2008 11:06 pm
Warped Cee Bailey windshield - K1200LT (REVISITED) st2en K1200LT 4 Apr 5th, 2006 11:19 am
