Removing the inside of the trunk's cover ... - BMW Luxury Touring Community
post #1 of 6 Old Aug 25th, 2008, 12:15 pm Thread Starter
Tonio's Avatar
Hi there ...
I'm trying to wire a 12 V. outlet inside the trunk to plug my MP3 & FM emitter, therefore I've tried to remove the plastic part inside the superior part of the top case. Unscrewing all the screws was quite easy, everything felt off ( back, loudspeakers, packet holder with 3rd stop light) but ... the thingy didn't want to come out !!!
Has someone already done this ??? I think so since I've already read about an outlet in the trunk.
If you're kind enough to help a frenchie that would be great
Tonio.
Tonio is offline
post #2 of 6 Old Aug 25th, 2008, 12:29 pm
Ajlelectronics's Avatar
Re: Removing the inside of the trunk's cover ...
Originally Posted by Tonio
Hi there ...
You don't need to strip it any further. Just thread a fishwire through the cable openings you have and pull your new cables.
Just pussin' through.
Ajlelectronics is offline
post #3 of 6 Old Aug 25th, 2008, 2:10 pm Thread Starter
Tonio's Avatar
I think that's what I gonna do ... I shoulda think of it before
Thanks Ajlelectronics
Tonio is offline
post #4 of 6 Old Aug 25th, 2008, 2:23 pm
If you weren't so far away, I would have helped you with it. I have a house in 22230 that I visit from time to time but I think that's still quite some way?
I took my power feed from the existing power socket, only slight drawback is that it is ignition switched. There is no choice if you want to retain the ease of removing the box via the two connectors.
Here's one I did earlier.....
ID:	19141   Click image for larger version
post #5 of 6 Old Aug 25th, 2008, 4:06 pm
MattKas's Avatar
+2 (on two LTs)
Matt Kas
"Riding Year around"
MattKas is offline
post #6 of 6 Old Aug 26th, 2008, 2:28 am Thread Starter
Tonio's Avatar
Thanks for help and I've quite understood what you did ... and I think I'll paste it on my Panzer
The trick is now to snail the wire !
Tonio is offline
Trike cover modifications Triker Trailers, Sidecars, & Trikes 2 Jun 1st, 2008 1:26 pm
Weather-proof cover Josmas Satellite Radio 6 Apr 15th, 2007 6:12 pm
Windscreen fasteners ajs K1200LT 17 Mar 5th, 2007 8:32 am
K1200LT on Whitney cover PhotoBiker K1200LT 5 Apr 17th, 2006 9:54 pm
