Stranded! - BMW Luxury Touring Community
post #1 of 8 Old Aug 23rd, 2008, 11:53 pm Thread Starter
Stranded!
Need some help now. We are at the Grand Canyon. The bolts for the rear brake caliper are gone! Both bolts have worked loose and are gone. The rear brake is just hanging there. We have the caliper pulled back out of the way right now with a zip tie. No fluid is leaking, as both the rear pads are compressed together and all the internal parts are intact. It is now late Saturday night 8-23-08. We had planned to see the Canyon tomorrow and then head to Las Vegas, see Hoover Dam and spend some time in Vegas and then to CCR on Tuesday. Any one out there have any spare parts, especially those bolts? Thanks for the assistance.
My cell is 770-331-8155 - call if you can help.
Raymond Weber
BadRay is offline
post #2 of 8 Old Aug 24th, 2008, 3:31 am
azpilot06's Avatar
Re: Stranded!
Ray,
Not sure if this will help, but per the parts fiche, at least one of the caliper bolts is showing as a M10 x 26. You may be able to find a high-grade replacement bolt (probably will find a M10 x 25) at a local hardware store, that can get you by until you can get to a dealer.
I'm thinking these might not be a part that a dealer will stock (as they're not that common a replacement), but am hoping otherwise for you.
Good luck!
2000 K1200LT Icon
2000 R1100RT-P
azpilot06 is offline
post #3 of 8 Old Aug 24th, 2008, 6:55 am
lionspaw's Avatar
Re: Stranded!
Also try at some of the auto parts stores, or an auto salvage yard you might luck out there and put a drop or two of BLUE loctite on the beginning threads of the bolts when installed it will help keep them from backing out again....good luck. Sounds like a nice trip except for the trouble.
'00 CANYON RED K1200LT "SURI"
I.L.M.O. THE BLUE EYED WHITE TIGER
lionspaw is offline
post #4 of 8 Old Aug 24th, 2008, 8:50 am Thread Starter
Re: Stranded!
Thanks for the info and ideas, we will see what develops today as we try to get back on the road again.
BadRay is offline
post #5 of 8 Old Aug 24th, 2008, 8:55 am
Re: Stranded!
Ray,
This is a stretch, but if you haven't found a replacement, I can pull mine off and overnight them to you. my cell phone is 813 267 8181. Phone is on, Let me know.
post #6 of 8 Old Aug 24th, 2008, 11:35 am
SilverBuffalo's Avatar
Re: Stranded!
Talked with Ray this morning, he was enjoying the Grand Canyon view,
he's able to ride the LT just no rear brakes.
Here's a couple of pics of the bolts you need,
(these are from my 02 LT) they are both one inch long with a 1/4" shoulder,
the forward one has an "affixed" washer and the rear one has a removable washer, I cannot see an advantage for either style.
The threads measure 18 threads per inch, I don't have a metric thread gauge but there is a -.072 on the same gauge.
The diameter of both bolts is 25/64 using a drill bit gauge that converts to .3906 metric for reference 10mm is .3937, so that's probably what they are.
A decent hardware store or marine center should have what you need, if not these are just a phone call away.
ID:	19126   Click image for larger version
ID:	19127   Click image for larger version
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #7 of 8 Old Aug 24th, 2008, 3:50 pm
JPSpen's Avatar
Re: Stranded!
OK, now that we've established you should be fairly able to get some replacements...
Why did these fall out.. That just usually doesn't happen unless they weren't properly tightened in the first place...Did you do your own brake service or did someone else try to kill you...? Inquiring minds want to know.
Put a little blue loctite on the new ones to be for sure for sure.
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #8 of 8 Old Aug 24th, 2008, 8:00 pm
Re: Stranded!
Torque the new bolts to 40NM (30 ft-lbs).
I just passed through that area in an un-airconditioned Jeep Cherokee (my son's) two weeks ago.
I've got to go back on the LT - when it's a little cooler!
Good luck.
Joe
EncoreJoe
"Ride, boldly ride, ... If you seek for Eldorado!"
'10 Triumph Tiger 1050
EncoreJoe is offline
stranded kickboxer K1200LT 8 Nov 2nd, 2007 6:47 am
Ralph Gray stranded in Texas/OK kdog Bike Talk 25 Sep 3rd, 2007 6:26 pm
HELP!!!!! Stranded!! tumbleweed K1200LT 15 Jul 16th, 2007 1:29 am
Almost stranded mwnahas Bike Talk 4 Apr 4th, 2007 8:52 pm
Stranded for 10 years. norsseman Humor 0 Sep 24th, 2006 11:35 pm
