%%$(#* Gas Pumps! - BMW Luxury Touring Community
post #1 of 16 Old Aug 21st, 2008, 10:23 am Thread Starter
%%$(#* Gas Pumps!
I had the joy this morning of my first spill while gassing the bike. It seems that the back pressure did not shut off the pump and I had a guyser of gas for a second until I shut it off manually.
Now I begin to wonder about the canisterectomy as I read somewhere this the overfill is what brings on the collapsing gas tank. So, is it time to do the procedure?
I did notice that a lot of gas ran out of the rear hose - maybe it was already done? Or is that normal behavior for a stock bike?
mowoc is offline
post #2 of 16 Old Aug 21st, 2008, 10:44 am
jers99lt's Avatar
Re: %%$(#* Gas Pumps!
The canister is connected to the tank, whereas the overspill cuff, around the fill hole, has a tube running down to about where the center stand is. That's probably where the leakage you noticed had come from.
HTH,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #3 of 16 Old Aug 21st, 2008, 11:44 am
fpmlt's Avatar
I too wonder if mine is there or not. Does anyone have a photo of where this can is, or was?
Frank
fpmlt is offline
post #4 of 16 Old Aug 21st, 2008, 12:05 pm
jers99lt's Avatar
Frank
It's fastened under the pillion and looks like a smaller version of a pop can that has 2 hoses attached to it. There's a picture of it in the BMW LT manual.
HTH,
Jer
Jerry Palma
jers99lt is offline
post #5 of 16 Old Aug 21st, 2008, 12:57 pm
lenny's Avatar
its under the rear trunk,,2 hoses running in 1 out
lenny is offline
post #6 of 16 Old Aug 21st, 2008, 2:48 pm
jers99lt's Avatar
Yep, that is correct. You can detect if the canister is there or if the tubes have been rerouted to bypass the canister by just removing the pillion seat.
I did the reroute procedure with just the seat removed. When I decide on what to do with the resultant space, I will remove the canister. It's far easier to remove the seat than the trunk, IMHO.
HTH,
Jer
Jerry Palma
jers99lt is offline
post #7 of 16 Old Aug 21st, 2008, 3:05 pm
yechave's Avatar
Five minutes to pop the rear seat, and no need to even cut the hoses. I was way too over zealous in my desire to disconnect the cannister tubing.....it would have been a much cleaner job, and is easy to reverse if for some reason you would want to, leaving what is there.
There are existing splices in the hoses. Plug the left side looking rear to front, and put the other hose as far down along side the rear of the battery, without having it hit the tire.
I did rip off the hot wire for the heated rear seat, not knowing that was routed in back, so may want to be aware of that.
yechave is offline
post #8 of 16 Old Aug 21st, 2008, 3:57 pm
Cooler on the east coast!!!
gglove's Avatar
Happened to me a few months ago boy what a mess. I had no problem with the canister. I was worried that it would start a fire as it ran down the side of my bike. I am even more careful now when I fillerup
G-Glove
2003 Silver LTC
gglove is offline
post #9 of 16 Old Aug 21st, 2008, 6:37 pm
kk610lt's Avatar
Wow, that's too bad.......
In my 30+ years of riding I have NEVER allowed a gas pump to run any way other than manually with my eyes looking down into the fill neck while gassing up a motorcycle. Just my method of filling up.
kk610lt
2007 K 1200 LT
2004 R 1150 GS Adventure
2002 K 1200 LT (totaled by a SUV 10-7-08)
1988 Concours
Why do bullets bounce off of Superman, but he ducks when you throw a gun at him?
kk610lt is offline
post #10 of 16 Old Aug 22nd, 2008, 7:47 am
Ron_Kendall's Avatar
I second that method of filling...I also don't fill while sitting on the bike...I have heard that gas will not ignite from the hot exhaust & I don't plan on experimenting to find out..I'll leave that to Myth Busters...Even when filling my car, I have it on the slowest setting, just in case...At work we have 3 pumps & all of them have that metal tab removed.
~ron~
"00 K1200LTC
"99 R1200C
"?? Indian Scout
"02 Uni-Go
"If you always tell the truth, you never have to remember anything"
Ron_Kendall is offline
post #11 of 16 Old Aug 22nd, 2008, 7:55 am
mtrevelino's Avatar
I just hate that, taking a perfectly good nozzle and removing the metal tabs. I guess that is why they make the gas caps a certain size so that you can jam it in the handle! The only thing with that is that you can only get the pump to run half the speed, unless you are really good at jamming the cap in the handle (LOL).
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #12 of 16 Old Aug 22nd, 2008, 8:13 am
gglove's Avatar
Too clarify I also always fill my vehicles manually. The time the spill happened the pump handle would not shut off, it stuck with out the auto shut off. I went inside to let them know and was told "oh ya we know about it" that was the last time I used that particular station.
G-Glove
2003 Silver LTC
gglove is offline
post #13 of 16 Old Aug 22nd, 2008, 12:50 pm
I work at a school bus company with 90+ drivers & some of them not the brightest when it comes to mechanical things...with the tab thingy removed they hold the handle on at full blast & let go when diesel fuel puchs back at them making a mess on the bus & ground...since everyone is assigned a bus, you can tell who does it...I have mentioned to them it seems to be counter productive with the thingy tab removed, but they say with their method someone is standing by the pump in case of an emergency...Management knows best.
~ron~
"00 K1200LTC
"99 R1200C
"?? Indian Scout
"02 Uni-Go
post #14 of 16 Old Aug 22nd, 2008, 1:12 pm
wacolt's Avatar
Makes you wonder how much the school district will have to pay for reclamation should they ever sell the property. And I'm not sure if the drivers actions of letting the fuel puke would be not be considered a "knowing violation." Hmmm.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
post #15 of 16 Old Aug 22nd, 2008, 8:10 pm
They are aware of it...just have to look at the ground by the pumps...One of the pumps has a concrete slab & it might be OK...But the other 2 are asphalt & the diesel soaks thru...
Reminds me of a recent problem a gas station owner had...20 years or so ago he closed his station...had the tanks removed...EPA gave him an all clear...then he rented the property out to other businesses...then wanted to sell...had a buyer ready to sign, but first the buyer wanted a ground sample test done...sure enough gas was found in the sample...he took his all clear papers to the EPA & they basically said they don't stand behind their test results & he would have to do it all over again...so there goes his retirement money.
~ron~
"00 K1200LTC
"99 R1200C
"?? Indian Scout
"02 Uni-Go
post #16 of 16 Old Aug 22nd, 2008, 10:20 pm
They need to get their auto shutoff fixed so that the drivers couldn't do this.
Another Brake Problem and a Near Miss chuckle K1200LT 31 Mar 14th, 2016 12:56 pm
Even Fuel Pumps can Fail! (Long) AlaskaFish North West 9 Jul 28th, 2008 12:51 am
Fuel Pumps can Fail (Long) AlaskaFish K1200LT 5 Jul 27th, 2008 7:13 pm
Tire Pumps jsciullo Tires 23 Dec 2nd, 2006 3:16 pm
