ABS Failure - BMW Luxury Touring Community
post #1 of 7 Old Aug 20th, 2008, 5:24 pm Thread Starter
Angry ABS Failure
Anyone besides me encountering failure of the BMW ABS control on a 1999 - 2001 LT?
Beemerdude 2001
American Legion Riders NE IA
Patriot Guard Riders
AMA Charter Life Member
AMA Ambassador
BMWMOA # 10524
Member: Jackpine Gypsies, Sturgis
09 GL1800A
76 Triumph T160E
77 R 100 S
beemerdude2001 is offline
post #2 of 7 Old Aug 20th, 2008, 5:57 pm
sheldan2's Avatar
Re: ABS Failure
before you give up completely on the abs, do a complete flush of the system and have the dealer reset the codes, and then see if the problem is still there... Many dealers are very quick to say your abs unit is toast and for a $$$$$$ we will gladly replace the unit. Check your battery as well, if it is more than 2 yrs old, it probably needs to be replaced, a lot of things start to go weird if the battery does not have a full charge
sheldan2 is offline
post #3 of 7 Old Aug 20th, 2008, 6:08 pm
JPSpen's Avatar
Re: ABS Failure
There is a way to get the codes and clear the computer after you've fixed the issue.
I'd sure start with a good flushing and set the sensor gaps.. That'd be a good start...
Just search for ABS reset...
Or maybe look at the bottom of the page here at the similar threads.
OK, I did the hard part and looked it up for you.. Click
Good Luck
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #4 of 7 Old Aug 20th, 2008, 6:30 pm
Re: ABS Failure
My 2000 did the exact same thing right after I bought it. It only had 8500 miles on it, but my guess is the brakes had never been flushed (happened in 2006 about 6 months after I bought it) I took it to the dealer, and he reset it, and within about 1000 miles, the abs failure light would come on. Did it a second time, with the same results. After that, the dealer told me the system was shot, and it would be 1500 or just for he parts. I decided I would just ride it, cause I wasn't going to spend that kind of money on a 2000 that wasn't worth a whole lot of money anyway. As I started reading on here that often times a brake flush, and sometimes a new battery would cure the problem. SO, I bought a new battery, and had the brakes flushed, and then took it to the dealer to reset the codes. Again, he told me the system needed replacing. That was 25000 miles ago, and the ABS work just fine. I do need to flush the brakes again, and will do it sometime soon. So before you do any drastic, get a new battery and flush the brakes.
jrlakin is offline
post #5 of 7 Old Aug 20th, 2008, 11:32 pm
slowflyn's Avatar
Re: ABS Failure
The ABS on my 2000 LT failed. Went through all the above mentioned and it really was dead. The bike was out of warranty. The dealer went to bat for me and got BMW to supply a new ABS unit if I would pay the labor. I would take that deal any day and got a new unit installed. Needless to say when it was time to trade the LT, South Sound BMW got my business and still does.
Darrel
'06 GT - Blue Honu
slowflyn is offline
post #6 of 7 Old Aug 20th, 2008, 11:48 pm
OldRed's Avatar
Re: ABS Failure
That's where I bought my 2001 LT. Can't tell you how happy I am to hear that! They are good folks.
2001 K1200LTC, "Mollie"
OldRed is offline
post #7 of 7 Old Aug 21st, 2008, 2:16 am
robasay's Avatar
Re: ABS Failure
I have had similar problems with my ABS. Two years ago I experienced a fault I took it to my local dealer and they replaced the battery as it was bad and then opened and cleaned a relay under the gas tank. No problems until this last March. ABS unit stuck on. I tapped the ABS unit and unstuck. Took it to the dealer and they reset the unit. Then about a month ago unit stuck on again. After reviewing the manual, I felt that that I needed to replace the relay located in front of the ABS unit. The unit is about $100.00. I also felt that the BMW (exide) battery was going bad even though 90% of the non riding time I kept a 750 ma battery tender on it for a charge. After replacing the relay I made arrangements to take the bike in to the dealer for a rest. I also took in my work order from two years ago to alert the service manager that the order indicated that they removed and cleaned the relay. However, when I removed the relay I found the original factory relay with the paint markings over the nuts. I explained this to the manager and he reset the ABS unit for free. The manager did indicate that there is another ABS relay under the gas tank toward the front of the bike. I have not checked the manual but I did not remember seeing anything about an ABS relay in that area. During the re-assembly I did flush out the front brake system. My assessment for my bike; the main cause of the ABS pump sticking is a weak battery. I replaced the BMW battery, now $170.00 with an Odessy 680 MJ at $170.00. Now the shop manager told me that the LT does not like the Odessy batteries and does some wierd things. I told him that I did not like Exide batteries. He told me that the BMW Exide battery has a built in fuse. Maybe it does, I don't know. I hope this helps with your diagnosis. I would try everything first before replacing the ABS unit. And if you have to replace the unit, you might look for one at a recycler.
Rob Asay
99 Canyon Red Lt
"The True Red Dragon"
1982 Honda "Silver Wing"
1986 Gold Wing Interstate "Blue Babe"
1978 Gold Wing
1976 Kawasaki 900
1967 Honda 305 Scrambler
robasay is offline
ABS Failure 2007 RT Recall Harleyujoe RT Series 6 Aug 8th, 2008 5:40 pm
ABS Failure bblalock K1200LT 9 Dec 27th, 2007 12:31 pm
ABS vs. Rear End Failure Tbird Surveys and Polls 11 Jan 22nd, 2007 9:12 pm
ABS Failure on 2000LT iowalt K1200LT 5 Jan 10th, 2006 11:20 pm
