Roll over Valve Hose Hazard!!! - BMW Luxury Touring Community
post #1 of 10 Old Aug 19th, 2008, 1:01 am Thread Starter
I have had several incidents of over pressure venting when removing the gas cap. On occasions even felt the tank shape change when the cap was removed. This weekend while performing the 12K shuffle I discovered the hose pinched shut. I would assume that it was assembled at the factory this way. The hose was pinched between the back edge of the fuel tank and the top left corner of the crankshaft cover. If you notice your tank venting air when the cap is removed I would have this item checked ASAP.
PWelty is offline
post #2 of 10 Old Aug 19th, 2008, 9:40 am
STARFIGHTER's Avatar
Re: Roll over Valve Hose Hazard!!!
often that hiss when opening the gas cap means the cannister has collapsed from overfilling.
IBA #38152
BMW-MOA 97667
Patriot Guard Riders
...and man of leisure
STARFIGHTER is offline
post #3 of 10 Old Aug 19th, 2008, 9:41 am
vernvernvern's Avatar
Another thing to check is your cannister under the rear seat. It's probably clogged. Most of us here have just disconnected it. In CA, I wouldn't tell my neighbor though. LOL
There should be no "swoosh" when removing the gas cap as BAD things will begin to happen inside the tank. Fix the problem ASAP!.
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #4 of 10 Old Aug 19th, 2008, 8:47 pm Thread Starter
You can't plug a removed canister... I removed the canister when this problem first reared it's ugly head. Unfortunately this cannisterectomy failed to solve the problem. The dealer failed to find the problem as well. The hose was pinched so hard and 12K worth of crankcase cover contact reshaped the line so badly I had to replace the entire hose. This is a significant problem if you take the bike up any altitudes above 4000 feet this could cause a catastrophic failure do to atmospheric pressure change.
PWelty is offline
post #5 of 10 Old Aug 20th, 2008, 11:17 am
Ok what about the mud dauber wasp that builds one in the end of the hose. What then? I know this was man made (or induced) but I don't see a catastrophic failure happening at 4000 ft. It is just a vent line and will collapse the tank and possibly damage the fuel sender. Yeah if you don't notice it you could suffer from fuel starvation just like if you ran out of fuel.
post #6 of 10 Old Aug 20th, 2008, 11:47 am
RonKMiller's Avatar
I was puking a quart or more of tranny fluid all OVER the place every time I cold started started my 88 Chevy truck - but - the tranny worked just fine! All I could think was man, this is going to be expensive... I kept dumping fluid in until I had the time to look at it.
I never could figure it out and finally took it to a pro for diagnosis. He pulled the pan, changed the filter, test drove and told me there was absolutely NOTHING wrong with the tranny (to the tune of $170.00).
While he was lowering it off the lift he poked his head up in the tunnel and noticed that the tip of the vent hose was packed with mud:
Courtesy of an insect just trying to build a nice home for his family.
"Like Butt-ahh!"
RonKMiller is offline
post #7 of 10 Old Aug 20th, 2008, 1:00 pm
I can't even begin to count how many "Check Engine" lights are set by spider webs in the hoses of car evaporative emissions systems....
Beautify America - Get a Tattoo!
2002 K1200LT (going, going, GONE)
Tat_n_Telle is offline
post #8 of 10 Old Aug 20th, 2008, 3:17 pm
RonKMiller's Avatar
HAHA - those little buggers set off my smoke alarms in my house every once and a while too - only at 3:00 am of course!
"Like Butt-ahh!"
post #9 of 10 Old Aug 20th, 2008, 4:00 pm
Unhappy Re: Roll over Valve Hose Hazard!!!
Who mentioned PLUG a REMOVED cannister?
I said to REMOVE the plugged cannister.
Somehow, your fuel tank isn't allowing air in as fuel is going out. I just mentioned ONE of many possibilities as a couple others have done. When you posted your question, I didn't see any mention of your already removing the cannister.
Sorry I tried to help.
Have a nice day, and good luck.
78 years young!
Converted HD rider.
Vern
post #10 of 10 Old Aug 20th, 2008, 5:22 pm
StillJustJerry's Avatar
Of course you can Plug a Removed cannister. How else to prevent Ron's bugs from making it into a nice insect motel while sitting on the back shelf?
Still Just Jerry
2005 LT "Lucky"
2003 Moto Guzzi Aluminum "The Fog"
StillJustJerry is offline
Don't Wiggle the Valve! wardenross K1200LT 11 Sep 5th, 2007 6:11 pm
brake hose failure, question on replacing the clutch line lavamanz K1200LT 3 Jun 1st, 2007 10:46 am
More Valve Adjustment Questions dglenn1 K1200LT 13 Nov 13th, 2006 4:26 pm
The Scphincter Valve DaFlake Humor 1 Apr 6th, 2006 1:46 pm
