Electrical Short - BMW Luxury Touring Community
post #1 of 3 Old Aug 18th, 2008, 11:43 pm Thread Starter
KMC1's Avatar
Electrical Short
My headlight is flickering when I hit bumps. It's affecting both the high and low circuit simultaneously. The headlight will "flicker" depending on the road surface.
My first thought is the common ground. However, the wrinkle that I noticed as I got closer to home is that the "flicker" is also cycling the radio on and off in sequence with the headlight. THAT has me confused.
Otherwise the bike is running fine, and it's not affecting the PIAA's that are wired through a fuse block directly to the battery, with the relay connected to the heated seats.
Any thoughts on where to start looking?
Thanks for the help!
(Down to ONE BIKE - ARGH!)
KMC1 is offline
post #2 of 3 Old Aug 19th, 2008, 12:25 am
Re: Electrical Short
Yeah.. check your battery cables.. make sure they are snug and clean.
then, find the brown wire from the bulbs ... that is the "ground".... trace them back to their harness plug.. I bet you will find a bad connection.
J.M.J...
Dcn Channing
post #3 of 3 Old Aug 19th, 2008, 6:45 am Thread Starter
KMC1's Avatar
Thanks Channing. I"ll let you know what I find - hopefully it is the ground in the headlight bucket. I forgot to mention that I have just installed a new battery last night so that (hopefully) shouldn't be the problem.
KMC1 is offline
GPS causing complete electrical shutdown BMWCharlie GPS 6 Jun 10th, 2008 4:21 pm
Bussed Electrical System? 2wheeljunkie Batteries, Chargers, & Electrical 8 May 12th, 2008 7:04 pm
Short guys only please bobmin K1200LT 14 Sep 21st, 2006 2:06 am
She Took A Short Nap avonfloater North West 4 Sep 16th, 2006 3:08 pm
