LT noise in MP3/GPS/Phone output/inputs - BMW Luxury Touring Community
post #1 of 3 Old Aug 16th, 2008, 2:12 pm Thread Starter
Have LT apart and about to run my cables from various devices to the to my Beahr Intercom System which sits atop the battery.
More than where to, I am looking for where not to run the wires. Anything that will cause or reduce bike noise interference?
I am thinking over tank/under the plastic on left side to stay away from the fuel pump, etc and maybe use the gas and tank as insulation from the other components.
The wires include the 2.5 and 3.5 for the Zumo GPS inputs and outputs, a separate 3.5 output for another MP3 Player, and a 3.5 input and output or the cell phone.
Any ideas. Thanks.
dhendy is offline
post #2 of 3 Old Aug 16th, 2008, 3:06 pm
Bouncer
eljeffe's Avatar
Re: LT noise in MP3/GPS/Phone output/inputs
Hint: Look for a ground loop isolation cable
I'm sure Raffy at www.motogear4you.com sells them
Also, you might look at the Baehr noise suppression cable
http://motogear4you.com/catalog/prod...roducts_id=133
__________________
El Jeffe
Plano, TX
'06 K1200GT Crystal Grey
'04 Sprint RS Caspian Blue
__________________
eljeffe is offline
post #3 of 3 Old Aug 16th, 2008, 6:12 pm
Axle's Avatar
remember if you run any cables "over" the fuel tank you will need a disconnect as well, giving you another contact point in the cable which will be subject to corrosion. cause that tank has to come out to check the air filter
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
5th gear stuck and noise started Tankist K1200LT 3 Jul 15th, 2008 11:04 am
Unconventional solution for the brake noise. Smith K1200LT 16 Oct 22nd, 2007 7:45 am
voice separation on the LT's loudspeaker jusufbw K1200LT 6 Oct 8th, 2007 10:03 pm
BMW CB and CQ HID Lights Creating noise? bman28 Intercom, CB, & 2-Way Radios 8 Mar 28th, 2007 2:55 pm
