Check your rubber valve stems. RECALL !! - BMW Luxury Touring Community
post #1 of 9 Old Aug 14th, 2008, 1:50 pm Thread Starter
Wolfgang's Avatar
Exclamation Check your rubber valve stems. RECALL !!
I had several that seperated between the threaded brass part and the rubber and assumed it was caused by the high heat on the rear wheel of the LT. Now I run across this recall. Mine were replaced a while back with chrome stems, now I am really glad I did it.
http://blogs.consumerreports.org/saf...stem-reca.html
You all may want to watch your rubber stems careful, since you can not tell who made yours without removing the tire.
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
post #2 of 9 Old Aug 14th, 2008, 2:18 pm
Re: Check your rubber valve stems. RECALL !!
But they are so cheap... and ... my profit margin is more important..
J.M.J...
Dcn Channing
post #3 of 9 Old Aug 16th, 2008, 10:49 am
shadowfever's Avatar
I wonder if I could blame my final drive failure on a recalled valve stem and get it replaced.
shadowfever is offline
post #4 of 9 Old Aug 16th, 2008, 1:40 pm
dukey33's Avatar
The failure mechanism of the recalled stems is different than the separation some have experienced. The defective stems are cracking near the base.
In either case, good cause to switch to thread-in stems instead.
-2000 K1200LT
dukey33 is offline
post #5 of 9 Old Aug 16th, 2008, 1:58 pm
kbikerider's Avatar
I wonder if more than 4% of them had failed before the NHTSA opened their investigation.
kbikerider is offline
post #6 of 9 Old Aug 16th, 2008, 3:50 pm
Those must have been on my utility trailer rims as they were less than a year old when the spare tire stem just fell off. Metal forever!
post #7 of 9 Old Aug 17th, 2008, 6:41 am
rattler50's Avatar
I had a flat on the rear a couple of months ago during a poker run here. It went flat just as I was coming off a side road and getting onto a main road. All of a sudden the bike got squirrely and I pulled over. The rear tire was flat but I couldn't find anything in the tire. I had it hauled in and they said the valve stem in the tire broke. That's a first for me. It cost me $104 for the tow and stem replacement................
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #8 of 9 Old Aug 17th, 2008, 3:13 pm
MikeERideWNC's Avatar
You should always replace the valve stem with every tire change.
When you check your tire preasure and bend the stem to get the guage on it, you are actually weakening the bond between the rubber and the brass.
When I change friends tires, I always install steel stems on their bikes.
It is actually cheaper in the long run.
Rubber stem is .37 bulk
Steel stem is .45 bulk
It does take more weight to balance the wheel, but my friends safety is worth it.
Visit
MikeERideWNC is offline
post #9 of 9 Old Aug 17th, 2008, 6:49 pm
wacolt's Avatar
I had the brass portion separate from the stem last year. Replaced both with new tires recently and, as common sense would dictate, will replace with each tire change from now on!
Good thing the separation occurred while parked at home and not in the boondocks between Taylor and Hearne!
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
Angled Billet Valve Stems dougholck GS Series 0 Aug 5th, 2008 9:44 am
Fitting the Motorcycleanchor Valve Stems? Jerod521 K1200LT 3 Dec 9th, 2007 4:27 pm
New tires and valve stems Brian-NC K1200LT 4 Sep 19th, 2007 5:50 pm
Angled valve stems Shogun54 Bike Talk 13 Jun 7th, 2006 10:40 am
angled valve stems tmgs K1200LT 33 Mar 13th, 2006 7:15 am
