Valve Cover Gasket - BMW Luxury Touring Community
post #1 of 8 Old Jul 1st, 2008, 7:53 am Thread Starter
browad's Avatar
Valve Cover Gasket
As many know from my many posts, getting ready to do my 24k. Pretty sure I will need a new valve cover gasket (or at least one on hand in case). Is this a BMW dealer item? Haven't come across it on beemerbonyard yet...
Part # would also be appreciated.
Adam
2006 K1200LT 2001 Kawi KLR650
The
wants YOU!
browad is offline
post #2 of 8 Old Jul 1st, 2008, 8:04 am
DanMartin's Avatar
Re: Valve Cover Gasket
Part # 11121464823
$23.80 at Chicago BMW
my dealer never seemed to have them in stock. Mechanic stated that they never changed them.
I re-use them 2-3 times.
dan
DanMartin is offline
post #3 of 8 Old Jul 1st, 2008, 8:33 am
I got real lucky last valve check. I undid all the cover bolts then went to eat lunch. When I came back the cover had separated (there is a small spring under it) cleanly from the gasket. The gasket (with the little dabs of sealant) was still firmly set to the head.
Usually I knock it off with a rubber mallet and this always loosens the gasket from the head. Might give it a try. Either way the gaskets are re-usable you just have to clean off the sealant at those key locations and re-apply if it comes loose from the head.
post #4 of 8 Old Jul 1st, 2008, 8:36 am
JATownsend's Avatar
Originally Posted by browad
...Pretty sure I will need a new valve cover gasket (or at least one on hand in case)
I bought a new one in preparation for my 24k service. When I got the girl opened up and cleaned the old one, I could NOT tell them apart. I guess having a spare is the right thing to do. But, now 40,000 miles latter, I don't know which one is which and they BOTH still look new!!
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
post #5 of 8 Old Jul 1st, 2008, 9:01 am Thread Starter
browad's Avatar
I'm hoping to not need it as well. Better to have and not need then to need and not have. Plus it's not too expensive. Just need to order that and some QDs and that's it.
Thanks for the part#. BTW, is it the same for all K1200LT model years?
Adam
The
wants YOU!
browad is offline
post #6 of 8 Old Jul 1st, 2008, 9:19 am
DanMartin's Avatar
Part number is for all K12lt's and possibly K1100 also.
dan
post #7 of 8 Old Jul 1st, 2008, 10:42 am
I wouldn't replace the valve cover gasket unless you need to. And you don't have to buy BMW's high priced gaskets, just buy the silicone seal "the blue stuff" and use that. It works great.
Shariff
Caveno is offline
post #8 of 8 Old Jul 1st, 2008, 10:45 am Thread Starter
browad's Avatar
Ordered the gasket. I don't plan on changing it, but would like one on hand. I hate to admit it, but I just realized that the realoem.com parts fiche has my 06 on it. You just have to select the LT/M. I was wondering why it stopped at 03 .
Thanks for the quick replies.
Adam
The
wants YOU!
browad is offline
Stripped Valve Cover Bolt reggosnell K1200LT 6 Feb 10th, 2008 11:22 am
Valve Cover Bolts Torque Settings?? Kenny K1200LT 5 Jul 21st, 2007 8:08 am
Valve cover gasket sealant REWDOC K1200LT 20 Jul 22nd, 2006 8:06 pm
